It is currently Sun Oct 05, 2025 7:56 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 56  Next
PostPosted: Thu Sep 02, 2010 6:15 pm
just sent tem and email asking about the fans
thanks for the link :)
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Fri Sep 03, 2010 5:39 pm
ok bit of an update on the cooling, as sugested by a mate of mine, i lowerd the temp that the fans come on at and gess what it seems to of helped when croosing now i see water temps of 75-85c on it dident go over 90c even when i gave it a bit of stick :)
BRD Page
PostPosted: Fri Sep 03, 2010 7:50 pm
[img][img]http://img130.imageshack.us/img130/9496/foto0163l.jpg[/img][/IMG]
i non't need fans any more, i just realized the tricks i become from a TTE engineer :lol:
PostPosted: Fri Sep 03, 2010 8:16 pm
how have you done that Sunny :) plz tell
BRD Page
PostPosted: Fri Sep 03, 2010 10:46 pm
just visit
http://gt4dc.co.uk/forum/viewtopic.php?t=2908&start=0
or in short:
- golpher 40mm radiator
- TRD thermostat
- pipe instead hose from radiator to water pump
- air buffles
- air escape (hood & under panel)
for the future i plan to build a simple channel for the radiator package and if the uprated water pump work fine on the new engine will go for a custom 3flow radiator
don't forget, KEEP COOL UNDER PRESSURE :lol:
PostPosted: Sat Sep 04, 2010 9:43 am
My car do the thermostat temp too on road and i only have the 2 first point of your list.
And i manage to keep under 85°C on the track after 15' with this MOD :
Full cooling panel (can i call this a big AirDuct?) for IC and RAD
PostPosted: Sat Sep 04, 2010 10:37 am
Hello
Before we all start directing air conditioned air into the intake
what is the optimal temperature for the engine to run at?
You must run a thinner oil at lower temperatures?
Is there any correlation between engine and intake temperatures?
Curious.
Stephen
PostPosted: Sat Sep 04, 2010 11:48 am
merlin, very well made 8)
i will do i a little bit simple, i just want to give the intercooler pre-radiator air baffels next year when i build a custom radiator
try point 3 (pipe) on my list, this was a big improvement on my car :)
toyokid, oil and water temps are controlled by thermostats, but you become more reserves
not just the temp. is crucial for the viscosity of the oil, also the bearing clearances and hertzian stress play in this game
no, there is no true correlation
folks,
a pushing type fan has only 70% of the erergy of a pushing type, as the rotor redirect the air before she must flow trough the straight fins of the radiator core, the air doesn't want this and makes a back pressure in front of the radiator that lowers the air flow
PostPosted: Sun Sep 05, 2010 7:48 pm
Great picture Bozo - that's a great baffle/air duct!
PostPosted: Sun Sep 05, 2010 11:53 pm
Dice ducting Bozo-Merlin :) Are the oil coolers on the left and right for engine and gearbox?
PostPosted: Mon Sep 06, 2010 9:19 am
Thanks all but it's mixer72 topic and i just want to give him an idea.
13 row on driver side for engine (too small, need a 16 row) and 13 row on passenger side for gearbox (probably a bit too big), but i don't want them on the way to rad so use hole in the CS bumper under indicator.
I actually work on the car, i will share you everything about "La GrOsse" as soon as the cooling system is complete (i only kept the EVO IC).
HS OFF
PostPosted: Mon Sep 06, 2010 12:26 pm
Excellent travail 8)
J'ai l'attention de faire le meme choses.
Looking at doing the same setup for my 185 track build - nice to see it done already - very useful as a template :D
PostPosted: Sat Sep 11, 2010 12:33 pm
update on the maping car is all runing great i will say that is does seem to be spooling and pulling harder than last time :) we did try and run it a t 1.6bar but it star to knock to much so left it at 1.4-1.5bar, rely happy with the whay it drives as for engine temps the water dident go over 93c and it was being puched very hard so thats good Greg my maper said that all the temps were very good, so it looks like to get any more power ill have to change to a biger turbo but that will have to be a mod for an other day :)
BRD Page
PostPosted: Sat Oct 09, 2010 5:19 pm
ok little update on the car, i have now fitted some nice new 12" fans
that fit nice on the ally rad
think i would of gone a bit biger with the fans
and new we have a nice swirl pot set up :)
BRD Page
PostPosted: Tue Nov 09, 2010 8:40 am
HELO,AN ADVICE I'M GIVING YOU,THE PIPES FOR THE INTERCOOLER ARE TWISTY AND LONG IT WIL BE MUCH EASIER AND A CLEAN WAY IF YOU FLIP THE INTERCOOLER UP SIDE DOWN
