It is currently Mon Oct 06, 2025 9:17 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Sep 04, 2008 7:38 pm
thanks jp its been *bleep* times of late with arm and knee injury
still waiting for package.. nothing yet can't even make my ecu adapters..
PostPosted: Wed Sep 24, 2008 1:22 pm
Hiya
I can't seem to find on that site connectors for a 165 as wish to make up an extension loom ( so as to be able to wire in for example emanage/safc anything really) and being able to solder things in in an easier enviroment instead of footwell nad so as i can return to standard just on quick removal
does anyone know where else i may be able to get them ? or another way to do what i am after ?
Cheers
Jingo11
PostPosted: Fri Nov 16, 2012 5:02 pm
Just to bump this, seems the ECU plugs are 'TE connectivity' unless I'm mistaken.
**** edit ***** this part No. may be wrong. Refer to original post for ECU PCB mount connector
ECU male socket:
http://www.te.com/catalog/pn/en/1-17876 ... 1-178764-6
Not yet managed to find a supplier / stock.
PostPosted: Fri Nov 16, 2012 8:47 pm
Nibbles wrote:
'TE connectivity'
Formerly known as Tyco Electronics, good *bleep*.
PostPosted: Sat Nov 17, 2012 2:23 pm
I know where the office is :lol:
Walked past it every day on my last work trip to Japan
PostPosted: Thu Dec 13, 2012 7:09 pm
Did the connectors ever arrive from online ? Were they ok to deal with ?
I have just put in quote requests with them and another company called legend electronics.
PostPosted: Thu Dec 13, 2012 9:09 pm
I never ordered. I think DJ did.
PostPosted: Fri Dec 14, 2012 1:02 pm
Very helpful. Not.
Sold out
Sincerely,
Joe Trezza
Legend Electronics Inc.
ISO9001-2008
140 OLD SAW MILL RIVER RD S.
HAWTHORNE ,NY 10532
www.legendny.com
Tel (914) 747-1777 Fax (914) 747-1770
-----Original Message-----
Sent: Thursday, December 13, 2012 12:33 PM
To: Joseph T.
Subject: Web RFQ to Legend
Legend Electronics RFQ
Qty Target Price Part Mfg Date Code
10 1-178764-6 TE Connectivity (Tyco)
Comments: Would be grateful if you have information on long term availability as new design.
Thank you for requesting a price on the following item:
Part Number: 1-178764-6
Manufacturer: TE Connectivity / AMP Brand
Quantity Requested: 10
Target:
We will e-mail you with the pricing information within 24 hours. If you have any questions, please e-mail us at cs@onlinecomponents.com.
Thanks,
Onlinecomponents.com
PostPosted: Fri Dec 14, 2012 1:36 pm
that could be a good thread to share some PDF's with you, i have the toyota connector manual here on my computer if anyone is able to upload them contact me and i will sent you them over -> 2,57MB :)
PostPosted: Fri Dec 14, 2012 2:54 pm
Send to me.
cddelect1@hotmail.com
PostPosted: Sat Dec 15, 2012 11:48 am
sent
PostPosted: Sat Dec 15, 2012 12:42 pm
Thanks sunny
http://www.cdd.co.uk/stuff/male%20waterproof.pdf
http://www.cdd.co.uk/stuff/male%20non-waterfroof.pdf
http://www.cdd.co.uk/stuff/female%20waterproof.pdf
http://www.cdd.co.uk/stuff/female%20non-waterproof.pdf
PostPosted: Sat Dec 15, 2012 11:30 pm
no problem 8)
PostPosted: Tue Jan 15, 2013 6:59 pm
The plot thickens a little. I'm hopefully ordering something else from online components, so wanted to make up minimum order with samples in the hopes of finding the correct sockets to go onto standard ECU loom.
The ECU plug listed in JP's original post seems to be the correct ECU plug and is in stock !!! D'OH.
To make a note of some other numbers I've found (will verify accuracy when the order arrives)
16 pin 040 series (to connect to loom) 174046-2 (cable) 174053-2 (pcb r/a) 174975-2 (pcb vert) (available from Farnell)
040 (small) tab contact 345164-1 (available from farnell)
070 (large) tab contact 173645-1 (available from farnell)
No amount of searching is showing up a 22 pin or 26 pin.
PostPosted: Tue Jan 15, 2013 7:10 pm
Update, it seems that the plugs I knew I'd seen are in fact a single block like the ECU. A closer look at the picture, it looks like the wires are soldered onto PCB pins.
http://www.ebay.co.uk/itm/Berk-Straight ... 0837727931
