It is currently Sun Oct 05, 2025 9:51 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 35, 36, 37, 38, 39, 40, 41 ... 56  Next
PostPosted: Wed Apr 11, 2012 7:20 pm
I do not have an over flow bottle any more as I have a header tank instead, witch I have a T into the bottom hose of the rad, the rad cap on the radiator doesn’t do anything now just a cap, the spout on the rad is for the air to get back to the header tank, the bottle top you can see in the slam panel is for my electric power steering pump reservoir
BRD Page
http://www.brooks-brd.co.uk/
 Post subject: lol
PostPosted: Wed Apr 11, 2012 10:04 pm
that explaines that lol thanks
:) sketch :)
PostPosted: Sun Apr 29, 2012 9:09 pm
just picked up the new bronze powder coated cam cover
BRD Page
PostPosted: Sun Apr 29, 2012 9:19 pm
That looks nice. :)
PostPosted: Sun Apr 29, 2012 9:41 pm
looks much even better in the flesh its a rely nice bronze :)
BRD Page
PostPosted: Thu May 03, 2012 7:45 pm
big day tomorrow its MAPPING day
BRD Page
PostPosted: Thu May 03, 2012 8:14 pm
Whooooo good luck! What are you hopeing for?
PostPosted: Thu May 03, 2012 8:47 pm
What are the main changes except for the inletmanifold?
Going for 1.6 bar again?
Good luck tomorrow.
ST185 CS #1845
PostPosted: Thu May 03, 2012 9:10 pm
shorter intercooler pipe work, fully portedand port matched head and manifolds, valves are now all sealing tigh,t turbo waste gate is now fully shut as it was lose be for and was losing spool up, yes if it will take 1.6 bar then that what it will be mapped at
BRD Page
PostPosted: Sat May 05, 2012 7:45 am
Had a good day bad day lol the mapper said the engine sounded good so that ok, It’s still in 1 piece lol but the is a problem with power to the ecu? Its only showing 11v so all the mapping is out and won’t be able to map it till its sorted. So guess what I’m doing today
BRD Page
PostPosted: Sat May 05, 2012 9:35 am
I know I may not fully understand the situation but is that indicating an unacceptable volt drop from the 12v source? Could it just be a breakdown in the conductor or faulty connection along the cable. Maybe just worth measuring resistance from +12 source to input of ecu.
:D
PostPosted: Sat May 05, 2012 9:05 pm
sorted the low volt problem, i have fitted some new wireing to the ecu so it is now getting 14v as it should be, just need to get ti back for remapp now
BRD Page
PostPosted: Sat May 05, 2012 9:35 pm
Nice 1, was it just some old dodgy wiring?
PostPosted: Sat May 05, 2012 10:26 pm
not shore? i had 14v at the batter and the igniton but just not 14v at the stock ecu wiering :( so just put a new feed to it all :)
BRD Page
PostPosted: Sun May 06, 2012 7:37 am
Whats the deal with it being sensitive electronics in the ecu? maybe its worth placing an inline fuse just incase.wouldn't want to write off the ecu if you were struck by lightening! :D
