It is currently Mon Oct 06, 2025 8:49 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 37  Next
PostPosted: Tue Mar 06, 2012 10:58 pm
I have no idea what it is!
What are these little bolts from? Or what do you want them for?
PostPosted: Tue Mar 06, 2012 11:04 pm
I have similar screws securing the adjustable links on my Formula Ford anti roll bars!
PostPosted: Thu Mar 08, 2012 9:51 pm
shop apt isn't answer me so i went a different way and clear a custom built
PostPosted: Mon Mar 19, 2012 9:44 pm
do that screw has a internal thread?
-> M3.5x0.6 inside???
http://www.shop-apt.co.uk/shim-screws/1 ... allen.html
PostPosted: Mon Mar 19, 2012 10:07 pm
Yes it seems to suggest it has an internal and an external thread.
PostPosted: Tue Mar 20, 2012 7:23 pm
the big question is about there is a hole through it......
for the moment i just know that there is no stainless option to be safe from rust
i also have a offert from a company which is 55€ for the two small screws, custom made :(
PostPosted: Tue Mar 20, 2012 9:02 pm
I suspect that you might be better just getting them custom made for the 55€ it will probably be easier in the long run.
PostPosted: Tue Mar 20, 2012 11:54 pm
I would still love to know what and where these are meant to go!
PostPosted: Wed Mar 21, 2012 4:14 pm
Sirius, i definetly go custom once i didn't find a perfekt solution :)
Don, this is top secret would i tell it you and i will become big problems with the CIA :lol:
i clear it once i know it works and / or it is finished, let me have a small secret for the while i just tell you it is nothing realy exciting but nice to have :lol: 8)
PostPosted: Wed Mar 21, 2012 7:30 pm
Sunny,
Don is the CIA, and needs to know everything..be careful !
2004 Subaru WRX
PostPosted: Wed Mar 21, 2012 11:04 pm
Sunny, now you really have me intrigued! I have ordered some more sodium pentathol 'truth serum' from central stores in Langley (CIA HQ) :lol:
PostPosted: Thu Mar 22, 2012 1:18 pm
the hell, i wasn't in know that they hunt me yet :lol:
PostPosted: Mon Apr 02, 2012 6:35 pm
small update,
and sorry Don, the screw missery becomes clear later :lol:
uprated oem water pump
the following two pictures shows the axial clearance without gasket
oem, is ~2mm + 0,5 for the gasket
[img][img]http://www.abload.de/img/oemclearancewithoutgaaxlwv.jpg[/img][/IMG]
and here the machined one, 0 clearance without gasket (target clearance of 0,5mm with gasket)
[img][img]http://www.abload.de/img/waterpumpmod2w5b67.jpg[/img][/IMG]
i also machined all edges, good to see the two angles of the oem plastic impeller pump seat
[img][img]http://www.abload.de/img/waterpumpmod1jxy3n.jpg[/img][/IMG]
and here a comparison of the two different pump housings, gen.3 GTE with the two angle seat and gen.4 with the simple one angle stainless variant
[img][img]http://www.abload.de/img/waterpumpgen346wyjf.jpg[/img][/IMG]
and here a how to do,
all 3S engines from gen.3 onward uses the simple stainless pump except the gen.3 GTE
i found that the stainless pump housing has enough material to machine the two angle seat at the target clearance so you need both housings, one where you get the angels measured and stainless pump housing to machine it
we did it on CNC turning machine, and was in need to built a bracket becouse the housing isn't able to get fixed centric without, then we measured the angles and programmed it
it takes ~2hours and cost me 100€, absolute ok i think :)
feel free to drop me any question if needed :)
PostPosted: Sat May 19, 2012 10:50 am
just some small things are done
some high heat screws for the manifold
[img][img]http://www.abload.de/img/highheat1ibu9q.jpg[/img][/IMG]
[img][img]http://www.abload.de/img/highheat2nfuj8.jpg[/img][/IMG]
and a selfmade tower bar, so it is easier for me to weld on mountings if i'am in need
a bigger update soon once the block is back from the builder
/EDIT
maschined intake manifold to fit the smaller haltech IAT thread
[img][IMG][img]http://www.abload.de/img/intakeairtemp2w6u9j.jpg[/img][/IMG][/IMG]
[img][img]http://www.abload.de/img/intakeairtemp1vyuo8.jpg[/img][/IMG]
PostPosted: Sun Jun 03, 2012 7:07 pm
today i got mail from Mr. *bleep*, my shortblock is ready and i will do some pictures once at home, the ones in the mail are way to small to post but it looks like a perfect job :)
a update to the head is also to follow, gave the combustion a polish and i will also calculate/ equal the volume, more soon
his name isn't that good to write in a english forum :lol:
