It is currently Sun Oct 05, 2025 4:10 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 56  Next
PostPosted: Thu May 06, 2010 12:24 am
Excellent service if it fits :D :D
Looks like Fun Weekend was a bit of a laugh then. I nearly went but, er, didn't in the end
PostPosted: Sat May 08, 2010 11:18 am
new 52mm 2core ally rad fitted
that sould help keep things cool :D
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Thu Jun 10, 2010 8:36 pm
bit of an update as some of my know i have bin getting over heating problem and it looks like it is the head lifting under boost, and the other thing i have now got is oil vapour smoke out the air filter :( and to add to that my oil pressure seem to be very low :?
But now we have some good new I have just checked the oil pressure with a Snap-on oil pressure gauge and all is well, at idle I’m getting 20psi and as soon as I rev the engine it goes up to 50psi so it is just my gauge or sender to the gauge
just been out for a spin with both the cam breather and idle valve pipe disconnected and I’m still getting oil vapour smoke out the air filter so I’m guessing it can only be the turbo seal on the cold side :( so its turbo off and send it back to TT and see if that will fix it under warranty as I have only had it 6months and done 600miles on it. not retorqued the head yet doing that Saturday so fingers crossed that will sort the head lift and my over heating
BRD Page
PostPosted: Sun Jun 13, 2010 11:09 am
What head gasket and bolts/studs did you fit? What was the torque?
Was the head skimmed, block decked?
PostPosted: Sun Jun 13, 2010 11:59 am
using ARP bolts a Cometic Metal Head Gasket 1.4MM. ok so we did a retorque of the head today and then did a sniffer test and all is good :) so its juts get the turbo back to TT and hope that fix it
BRD Page
PostPosted: Sun Jun 13, 2010 6:24 pm
ARP bolts or studs?
What torque did you use?
Did you use the moly compound supplied?
PostPosted: Sun Jun 13, 2010 6:55 pm
ARP studs , you meen the the ones that you fit the stud into the head then fit the bolt to tighten it up?and yes we used the moly compound supplied we have retorqued them upto 70lbs witch is just over what thay say to do with them
BRD Page
PostPosted: Mon Jun 14, 2010 5:35 pm
Good stuff regarding the studs... can't find what I did mine too, I have it filed somewhere!
I used a 3 stage process, gradually increasing the torque applied to the studs each time
PostPosted: Mon Jun 14, 2010 6:55 pm
any chance u could post up the 3stage that u did cheers
BRD Page
PostPosted: Mon Jun 14, 2010 7:34 pm
Car Model: ST165
Louis,
probaly the same "staged" torque procedure that you recently cut n pasted from a thread on mr2oc by noshoes and in teh workshop manual
eg go round in sequence all 20 / then 40 / then 65 , back off and do it 5 times etc
http://www.arp-bolts.com/Tech/TechInstall.html
ST165 turbo 4WD
PostPosted: Sat Jun 19, 2010 1:22 pm
update on the turbo smoking, i took the turbo off to day and you can see all the oil that the seal is letting out
BRD Page
PostPosted: Sat Jun 19, 2010 3:13 pm
doh,
is that your newish tt hybrid?
PostPosted: Sat Jun 19, 2010 3:27 pm
yes mate it is there s148 and i have only done about 600miles on it
BRD Page
PostPosted: Sat Jun 19, 2010 4:54 pm
Not good
I guess a call to TT is the next prder of business now :(
Hopefully they'll stand behind the warranty....
PostPosted: Sat Jun 19, 2010 5:06 pm
thay will be getting a call nice and early monday morning and i wont be taking any stick from them
BRD Page
