It is currently Mon Oct 06, 2025 10:08 pm
Post new topic Reply to topic  [ 401 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 27  Next
PostPosted: Tue Feb 17, 2009 4:31 pm
That's the suspension work I'd love to do too. Have you got a chance to weigh the new parts and compare them to stock? Nice work again! :)
PostPosted: Tue Feb 17, 2009 6:31 pm
WOW :shock:
this project is crazy :lol:
as a reader of the "japanese performance mag" i will see this car in the mag when it is finished 8)
PostPosted: Tue Feb 17, 2009 6:36 pm
Nice a-arms. Now if I can figure out how to make me a set of those for the 185.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Tue Feb 17, 2009 6:37 pm
I'm suprised that the front arms aren't adjustable but I have no idea how you'd make them so or what you'd adjust :lol:
The weight saving on the front must be "quite" large - 2x banana arms, 2xsee-saw arms and 2xFig8 all of which are cast from solid heavy :D
PostPosted: Wed Feb 18, 2009 1:06 am
The pics are really just a sneak preview. There's still a lot of work to be done. The subframes and the suspension components have just been temporarily assembled on the chassis. Eventually everything will be removed and the chassis/shell sent for painting.
The planned adjustment on the front suspension is toe-in and toe-out. Camber angle can be adjusted via the top mounts or camber plates on the hubs.
PostPosted: Sun Feb 22, 2009 1:02 pm
Great stuff Don!
 Post subject: Update Post24/06
PostPosted: Wed Jun 24, 2009 11:14 pm
Latest update from my track car project. Cage has been installed along with the air jacks
The body shell had to be cut back to accomodate the roll bar element between the top of the A and B pillrs
Front Air Jack
Rear Air Jack Locator
PostPosted: Thu Jun 25, 2009 7:13 pm
That's looking awesome Don. I can't wait till mine gets caged up. Is there a specific reason why you went for a cut bar in the side X's instead of 2 V-shaped bars? They're quite a bit safer in terms of side impact. Air jacks are hardcore! (I'm not going that far :lol:)
PostPosted: Thu Jun 25, 2009 8:23 pm
the cage is awesome, wounderfull welding :)
PostPosted: Fri Jun 26, 2009 12:09 am
Meurz wrote:
.... Is there a specific reason why you went for a cut bar in the side X's instead of 2 V-shaped bars?
Thanks Rene :D. I'm not too sure what you mean by the 2 V bars?
The cage has been built from cold drawn high carbon steel (CDS) rather than T45. This means that it does not need to be an FIA homologated design. Despite this we have attempted to build the cage to be compliant with the FIA standard. The only exception I can see is the omission of the diagonal brace between the main roll hoop and the top door bar. I think we may aell add this just to be sure!
You might find the info below of interest:
According to the MSA 'Blue Book' -
For all Touring Car rollcages homologated by the FIA after 1999, the presence of the rollcage in the door aperture must comply with the following criteria (see illustration FIA 253-17D)
o Dimension A: Minimum 300mm
o Dimension B: Maximum 250mm
o Dimension C: Maximum 300mm
o Dimension D: Maximum 100mm (from upper corner of the windscreen, without the seal)
o Dimension E: Not more than half the height of the door aperture
MSA-certified and non-homologated rollcages constructed after 2000 in accordance with Appendix 2, drawing 12 must comply with the above diemnsions.
PostPosted: Sat Jun 27, 2009 11:54 am
starting to take shape very nicely indeed Don.
Is it off for paint next?
PostPosted: Sat Jun 27, 2009 12:26 pm
I wish!...........there's still quite a few little bits and pieces to do. Small but time consuming things. I had a 'seat fitting' now that the Recaro is in and we have the quick release steering wheel. The steering column is bespoke but will use the OEM universal joint where it splines onto the steering rack.
Currently the seating position is too far forward by around 80-100mmso need to match that to the steering column lenght. With your own classic Itialian racing driver physique you will be familiar with this predicament :lol:
PostPosted: Sat Jun 27, 2009 1:41 pm
TrackToyFour wrote:
With your own asleep at the wheel posture you will be familiar with this predicament :lol:
Fixed that for you Don :D
PostPosted: Sun Jun 28, 2009 10:52 pm
I hope this 10 sec MS Paint drawing makes sense:
I've read and been told that the design on the left, with a cut bar welded onto the other to form an X - which has been used for ages - is considered less safe than the 2 bent bars welded together (with triangular pieces in the sides like yours obviously). WRC cars (are going to) use the design on the right (in the future).
I believe there also was an article about it on wrc.com, with some engineers from BP Ford explaining the advantages. It was also about the cut X vs double V design iirc.
Thanks for the dimension info. I'm sure the guys who're going to build mine have all specs needed as they do FIA cages for grp A8, N and R rally amongst others but that image makes it very clear. Thanks! 8)
PostPosted: Mon Jun 29, 2009 12:21 am
Thanks Rene, we thought this might be what you meant. I believe the WRC and FIA GT guys all use T45 tube to save as much weight as possible. Its more likely to snap than CDS. Over the last couple of seasons a number of WRC drivers and co-driver have had serious accidents
