It is currently Mon Oct 06, 2025 3:43 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 37  Next
PostPosted: Sat Oct 30, 2010 6:24 pm
some pictures of the head, it is not completed yet as i'am still waiting for the cat cam gears
a little to late but now i found a company that does custom titan turbo internals
http://www.mwh.de/
we will see, possible i have some work for them :)
PostPosted: Sun Oct 31, 2010 3:25 pm
Sunny > Looking very good, where di you get the TTE chargecooler core from?
PostPosted: Sun Oct 31, 2010 3:42 pm
Hi Mook,
thanks, it is from a friend from CH, but a other friend get his intercooler from a part search at
http://www.rallycarsforsale.net/
just add your seach in the wanted section
the other option is wevers in NL
http://www.weverssport.com/web/
1250€ + VAT + delivery
PostPosted: Sun Oct 31, 2010 6:18 pm
Yoinkers! Not cheap then :o
PostPosted: Sun Oct 31, 2010 9:29 pm
thats true, but i have some infos that this unit is really efficient, better then HKS air to air units
PostPosted: Mon Nov 01, 2010 5:47 pm
today i want to start to adjust the valve clearance but i noticed two problems
1. the intake cam have the wrong end, a gen.3 end but should have a gen.4 cam angle end
Uploaded with ImageShack.us
2. the shim's i have are all to thick so i can't can adjust them without buying a lot of shim's, i decided to give the head the general toyota importer from austria to do the adjustment
here the specs of the camshafts
> - intake camshaft: #3180: 269°@0.1mm/235°@1.0mm/11.51mm/2.43mm@108°/vc
> 0.250mm
> - exhaust camshaft: #3175:
> 249°@0.1mm/215°@1.0mm/10.26mm/0.56mm@-116°/vc 0.250mm
PostPosted: Wed Dec 01, 2010 7:12 pm
just a picture of the adjustable cam gears
PostPosted: Thu Dec 23, 2010 8:58 pm
small update
2nd version of the fuel rail, now with damper
[img][img]http://img96.imageshack.us/img96/733/foto0289p.jpg[/img][/IMG]
slightly modified water outled, AN6 water connector for the turbo
[img][img]http://img97.imageshack.us/img97/4575/foto0291u.jpg[/img][/IMG]
blanked throttle body connector
[img][img]http://img843.imageshack.us/img843/74/foto0292.jpg[/img][/IMG]
and who knows a gen.3 water outlet know the difference, there are no 1000 sensor in it just one for the ECU and combi meter
[img][img]http://img573.imageshack.us/img573/5741/foto0293.jpg[/img][/IMG]
denso 850cc injectors
[img][img]http://img211.imageshack.us/img211/4485/foto0294.jpg[/img][/IMG]
that is it, i just hope to buy the turbocharger in january or february
PostPosted: Thu Dec 23, 2010 9:47 pm
Gen3 is only 2 sensor, have you ever seen EUDM gen2 :lol:? 4 sensor and 1 charcoal canister valve :oops:
nice MOD for turbo and trottle ;)
PostPosted: Fri Dec 24, 2010 1:34 pm
gen.3 do also have 3 sensors in front of emission laws but not in GB
- EFI
- Combi Meter
- carbon filter of the fuel tank
oh yes, the gen.2 is one step more horrible :lol:
PostPosted: Fri Dec 24, 2010 3:51 pm
gen.3 JDM have only the 2 first you list
having a second hole in the pipe for a BOSCH / VDO sensor is nice for an aftermarket dash / gauge.
PostPosted: Sat Dec 25, 2010 1:24 pm
oh yes, a jdm engine is perfekt for this even i would not mount one in the elbow, i love to eliminate them :lol:
PostPosted: Thu Jan 06, 2011 9:22 pm
new post was comin in yesterday, gen5 throttle body and valve cover
the intake manifold has to be machined to so that the TB fit and it could be hard but the IC will possible fit with the valve cover
PostPosted: Wed Jan 12, 2011 11:08 am
what the reason in gen5 rocker cover?
PostPosted: Wed Jan 12, 2011 7:41 pm
the issue is that i can't can use the gen.4 cover in conjunction with the water to air intercooler core, and as toyota went back to a center feed manifold on the gen.5 i decided to try it
i also can't can use the gen.3 as there are no threads for the COP's, but if the gen.5 won't fit i'll try to make them
we will see :)
