Author |
Message |
coldel
Posted: Mon Oct 23, 2017 9:39 am |
Group N |
Joined: Sat May 16, 2015 8:21 pm Posts: 169 Location: Richmond, the southern one
Any idea on where to get one?
_________________ "Have to say this is one of the nicest ST205's I have ever seen. Certainly the nicest I have seen in a long while" Mr Sirius, South Coast Workshop & general all round nice bloke
Top |
cms-gt4
Posted: Mon Oct 23, 2017 1:14 pm |
Junior WRC |
Joined: Tue May 23, 2006 8:06 pm Posts: 595 Location: Knoxville, TN USA
The 16x- 7th gen all use the same style shift rod. I'm using a short shift rod from a ae92 in my 185. I just bought some thick bushings the size I needed to raise the shift assembly for clearance. I also picked up an oem 7th gen shifter which has similar dimensions to the short shifter made for the car for much less than the short shift kits.
_________________ Coldiron (Cold - Iron) 1992 Celica Gt4 RC Conv. St205 swap http://www.noritoy.com
Top |
coldel
Posted: Mon Oct 23, 2017 5:02 pm |
Group N |
Top |
cms-gt4
Posted: Mon Oct 23, 2017 8:13 pm |
Junior WRC |
It may. The ball in the center and cups should be the same size. I do not know how much longer thevlower rod of a 7th gen shifter is. That may affect inner clearance. That is why I suggest an oem one. Keep in mine you may need to bend or cut and weld the upper section depending on angle. The 5th gen tilts back so I have to modify the 7th gen one on top for a more optimal angle.
Top |
coldel
Posted: Tue Oct 24, 2017 11:25 am |
Group N |
OK thanks. Any other sources of getting one? I have seen some sites in the US but its going to come out around £250 all in to get it here.
Top |
cms-gt4
Posted: Tue Oct 24, 2017 5:14 pm |
Junior WRC |
Do you have local junk yards? That is likely your best bet. There or ebay. If you look for a oem 5speed one from a 7th gen I imagine they are pretty cheap.
Top |
