It is currently Sun Oct 05, 2025 12:19 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 49, 50, 51, 52, 53, 54, 55, 56  Next
PostPosted: Fri Mar 25, 2016 7:37 pm
so that's it more or less done just a few bits to tidy up, but its alive :)
https://youtu.be/mlaRaQVXve8
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sat Mar 26, 2016 7:48 pm
so that's it all done, just need to tax it and run the engine in ready for mapping
BRD Page
PostPosted: Sun Mar 27, 2016 1:45 pm
nice to get the Beast out side :) and give the garage a good clean
[url=http://s521.photobucket.com/user/gt4louis/media/Mobile%20Uploads/20160327_124112_zpslaasythf.jpg.html]Image[/url
BRD Page
PostPosted: Mon Mar 28, 2016 11:31 pm
Very neat!
PostPosted: Sat Apr 02, 2016 6:50 pm
new volt gauge fitted, charger temp sensor working and new charging socket fitted
BRD Page
PostPosted: Fri Apr 29, 2016 8:19 pm
new switch set up read to fit
BRD Page
PostPosted: Thu May 19, 2016 7:08 pm
Well it's all in wired up and all works
url=http://s521.photobucket.com/user/gt4louis/media/Mobile%20Uploads/20160512_161846_zpsqymkojgr.jpg.html]Image[/url]
BRD Page
PostPosted: Thu Jun 09, 2016 10:41 pm
A quick Question if I may....
Comparing your old dyno plots
1) Dated May 2011
2) dated October 2014
Was this the effect of cams alone or any other major engine changes?
PostPosted: Thu Jun 09, 2016 11:51 pm
Main thing is the side feed inlet manifold and the tubilar exhaust manifold. The rest is the same
BRD Page
PostPosted: Fri Jun 10, 2016 1:04 am
And cams?
PostPosted: Fri Jun 10, 2016 8:19 am
no same JUN 264 cam and we still not played with the setting on the cams
BRD Page
PostPosted: Fri Jun 10, 2016 11:37 am
It's interesting that you have lost 50 lb/ft of peak torque and around 1000rpm of spool! Yet gained little bhp but do now have a very nice smooth torque curve.
It appears that the second run was probably also done in 3rd?
Maybe you are simply running less boost in the mid-range now?
It's probably nicer/easier to drive now but I can't help thinking that for hillclimb the earlier shot of torque would be quicker?
PostPosted: Fri Jun 10, 2016 12:01 pm
The last map was done on the road and the mapper did say there was more left and could of added more timing but wasent happy doing that on the road need to be done on a dyno
BRD Page
PostPosted: Mon Jul 25, 2016 10:24 pm
ok so not shore were I got upto with the build but iv had to have a new block built as I had managed to over hone the block and when at idle the engine was not happy and was smoking witch after a strip back down we found the bore to be out of shape :( so now were are doing a full short block rev3 rebuid to go with my rebuilt 185 head, witch is now running under bucket shims.
few photos of the build so far
showing the difference in the bores
rods getting weighed then matched balanced
all ready for the head to go on
and a cam cover breather mod
BRD Page
PostPosted: Wed Jul 27, 2016 9:14 pm
bit more done
all ready for the head to go on tomorrow night
BRD Page
