thats true, the PCV valve isn't a true problem as it is closed under load, you are also correct that there is a slighly vacuum in the intake hose which helps to vent the crankcase, but the oil mist
effect the detonation point heavy, not that problem on a mass produced car but on a race engine of interest to get more performance out of it, but nothing is for free you pay the bill you list with at the 3 points
i'am pretty sure that there will be not to many vacuum (or no) in the crancase when the PCV is opened, it becomes air from the crankcase ventilation back so there will
be just a flow, and then there are still cylinders that works and at least at idle i do not need power but when i need it the valve is (must be) closed
small interloop, you raise the mean effectice pressure the same points you lower the pressure in the crankcase
the exhaust point is a little bit dangerous, you must be sure at every running point of the engine that the air gets out of the crankcase and not the exhaust gas to the
crankcase
the vacuum pump isn't that perfect, nothing has a 100% efficency, the power the pump takes is more then the power you win on the engine, so why are race (!) engines out there
that use a mechanical vacuum pump then......it is a aerodynamical answer, at around 10.0000rpm the air resistance of the crank effect the power but without air (or better air/oil mix)
there is no restriction
for example, on a 3liter engine you win ~25kw at 10.000rpm, and with air in the crankcase you loose up to 30kw at 12.000rpm
but what did this mean to the 3S-GTE......correct, you will not find so much of them reving that high, 7-8000rpm drive most of us,
at this stage you loose nearly nothing even the crank has no aeridynamical design
all in all i found a simple air filter on the oil seperator is simple, cheap and the oil mist in the engine bay is not that much after some years (and protects against corrosion
), the filter itself also still works without cleaning
and is not blocked
