It is currently Mon Oct 06, 2025 11:27 pm
 Post subject: clutch problem
PostPosted: Fri Jun 22, 2012 5:24 pm
driving the car today st185 celica :D then all of a suddern the clutch wont relise i.e car of put the gear stick in neatrul start the car depress clucth move into first wont go in tried second the same had a new race clutch put in and not much travel in the pedal almost touches the floor when it was working now if i rev the car in gear with clucth depressed the car moves forward is there any adjustment anywhere as will be looking the weekend any help is appreciated :oops:
:) sketch :)
PostPosted: Fri Jun 22, 2012 5:50 pm
http://wiki.gt4dc.co.uk/index.php?title ... utch_pedal
PostPosted: Fri Jun 22, 2012 5:55 pm
thanks thats a great help
:) sketch :)
PostPosted: Fri Jun 22, 2012 6:04 pm
Whip the starter off to allow access to the clutch cover bolts and check all 6 (I think) are tight.
Adjust clutch pedal to give more travel (as above)
If all else fails, it's a broken clutch plate, either cracked friction material or a spring come out.
PostPosted: Fri Jun 22, 2012 6:55 pm
Your not having much luck are you mate, lol :D
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Fri Jun 22, 2012 7:19 pm
no lol been rebuilding it as a project which was running but had a few walls to climb lol but learning and once complete will be nice
:) sketch :)
PostPosted: Fri Jun 22, 2012 7:59 pm
Other thing on the 185, the pedal box is prone to cracking / braking and once broken pressing the clutch tends to bend the remaining pedal box rather than pushing the master cylinder pushrod.
Easy signs to spot-
1- Clutch pedal sits fairly low compared to brake pedal when released.
2- Pull the pedal upwards fairly hard with your hand. If it comes up more than a few mm then this is probably the problem.
PostPosted: Fri Jun 22, 2012 8:00 pm
ok did look earlyer and it seemed the same height as the brake but will double check
:) sketch :)
