It is currently Wed Oct 08, 2025 8:52 am
PostPosted: Fri Jun 22, 2012 2:06 pm
back of the block, square plug
PostPosted: Mon Jun 25, 2012 8:05 pm
ahhhh help trying to fit yhe knock sensor through the wheel arch but i cant even get my hand close to it do i need to remove somthing plz help
PostPosted: Mon Jun 25, 2012 10:12 pm
falce alarm track rod arm off and a bit of spanner rash later its done. its never ending with this car!
PostPosted: Mon Jun 25, 2012 11:15 pm
Before you go pulling everything apart reset the ECU by pulling the FI fuse or disconnecting the battery for a few seconds, this will wipe any stored codes that might arisen from the fuel cut problem then if it happens again then you know you have a fault. Dorris
Black CS 2771
PostPosted: Wed Jun 27, 2012 6:57 pm
hi thanks for the reply mate tried that 3 times before i baught the sensor it was just such a pig to get done. there aint nothing but problems with this car haha
PostPosted: Fri Jun 29, 2012 3:59 pm
Unfortunately some cars are like that, the knock sensor is not in the best place to get at.
I’ve just rebuilt my engine and wasn’t until I was reconnecting everything I realised I had the wrong knock sensor in place so had to swap it but I was lucky as I still have all my suspension stripped down.
As is cured it then? Dorris
Black CS 2771
PostPosted: Fri Jun 29, 2012 7:21 pm
well the knock problems are all sorted but it seems like there is a clicking when im on boost coming from the controller or the solenoid. also it is dropping boost in 5th other wise its fine
Im actually looking at a set of gen 7 leather seats for the car :-)
