It is currently Mon Oct 06, 2025 7:35 pm
 Post subject: fuel cut
PostPosted: Wed Jun 20, 2012 7:40 pm
driving my st185 gt4 today and reaching 3k approx just as boost was charging up it cut out does this in every gear am i right in thinking this is the fuel cut defender and if so whats the best way to get round it
:) sketch :)
PostPosted: Wed Jun 20, 2012 8:00 pm
How do you mean it just cuts out? Does it jolt like ur hitting a wall?
PostPosted: Wed Jun 20, 2012 8:04 pm
yes engine managment light comes on then goes off
:) sketch :)
PostPosted: Wed Jun 20, 2012 8:07 pm
It does sound like fuel cut do you have a aftermarket boost gauge or boost controller on the car?
PostPosted: Wed Jun 20, 2012 8:08 pm
Do an error code check to confirm what the fault is.
On a 185, once boost cut has happened you need to reset the ECU otherwise it runs a safe mode and boost cut triggers at a much lower level.
On a 205, boost cut automatically resets and normal operation re-commences after a few seconds.
could also be knock sensor fault, this triggers at 3K RPM but just retards ignition and limits boost doesn't cut completely.
PostPosted: Wed Jun 20, 2012 8:45 pm
ok had a new knock sensor 6 months ago hasnt been on the road since
:) sketch :)
