It is currently Thu May 23, 2024 6:10 am
PostPosted: Tue Jun 05, 2012 2:05 pm
all my other lights work hazards and main lights but no indercators have checked the fuse and its fine to be sure i even changed it for a new 1 any help appreciated
:) sketch :)
PostPosted: Tue Jun 05, 2012 2:16 pm
possible indicator relay??
PostPosted: Tue Jun 05, 2012 2:21 pm
didnt think of that lol where is it located on a st185 my wiring diagram is the best
:) sketch :)
PostPosted: Tue Jun 05, 2012 2:22 pm
What model have you got?
Can you hear a clicking sound from the indicator relay when you first turn them on?
On the ST205 the indicator relay is below the steering wheel and above the peddles, and is quite loud.
Probably similar on the other models though?
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Tue Jun 05, 2012 2:30 pm
nothing at all got a st185 import
:) sketch :)
PostPosted: Tue Jun 05, 2012 2:48 pm
ST205 but may be similar?
Right of pedals and just a bit higher on side wall, there is a block with cables and connectors and the indicator relay as indicated in the picture.
You can hear it and feel it easily when it clicks.
Best seen when laying on your back on the drivers seat with head touching pedals.
Just got soaked taking this, so I hope it helps:)
Uploaded with ImageShack.us
PostPosted: Tue Jun 05, 2012 3:15 pm
thankyou almost the same but having a downpoor so waitnig to double check
:) sketch :)
PostPosted: Tue Jun 05, 2012 3:54 pm
Errm
Wouldn't have thought its gonna be the relay if the hazard lights are working.
More likely to be a fuse or the switch itself
1990 JDM ST185 Grey.
ST205 head gasket.
ARP head bolts.
ST205 Koyo Rad. (almost)
Front mount intercooler.
Colder plugs.
3" decat pipe.
4 Branch manifold.
PostPosted: Tue Jun 05, 2012 3:57 pm
Yea, suppose it wouldn't work at all.you have checked the fuse though right? does the relay click when hazards are on then?
PostPosted: Tue Jun 05, 2012 5:04 pm
ST205 head gasket.
ARP head bolts.
Colder plugs.
3" decat pipe.
4 Branch manifold.
PostPosted: Tue Jun 05, 2012 5:12 pm
thought the hazard ran off a diffrent relay
:) sketch :)
PostPosted: Tue Jun 05, 2012 7:09 pm
never know any car to use 2 relays to do one job
no point
all the hazard switch does is introduce a live without ignition and connect both sets of indicators.
all the flasher unit does is well flash.
basic timer relay
ST205 head gasket.
ARP head bolts.
Colder plugs.
3" decat pipe.
4 Branch manifold.
PostPosted: Tue Jun 05, 2012 7:20 pm
fair enough
:) sketch :)
PostPosted: Wed Jun 06, 2012 2:40 pm
good news all it was was a lose relay phew
:) sketch :)
PostPosted: Wed Jun 06, 2012 3:48 pm
Good news that wa the relay in the end, nice easy fix
