It is currently Tue Oct 07, 2025 7:31 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat May 26, 2012 7:08 pm
If you have spark and fuel then the only thing that would stop it firing would be timing/dizzy. You say you've changed the rotor, dizzy etc. Did you disturb the timing when you did this? There have been a few cases of dizzy/rotor failure due to old age.
PostPosted: Sat May 26, 2012 7:10 pm
carnt havnt got the man power lol or the room to
:) sketch :)
PostPosted: Sat May 26, 2012 7:27 pm
any ideas on y it smells of fuel at the rear
:) sketch :)
PostPosted: Sat May 26, 2012 8:40 pm
carnt bump it havnt got the man power plus dont no if it will start on a bump and i live on a hill if it dont start i carnt push it back up plus ive got a strong smell of fuel from exsaust just checked
:) sketch :)
PostPosted: Sat May 26, 2012 11:11 pm
Could be possible timing fault but doesn't the rotor arm have a notch and can only be fitted one way.dont suppose you slackened the dizzy bolts at any point and dizzy timing has changed? definatly sounds like fuel is making it into the cylinder so I'd be checking timing :)
PostPosted: Sun May 27, 2012 12:45 am
You say it started once but you stopped it. How long did it run for
PostPosted: Sun May 27, 2012 8:16 am
approx 2-3 mins but had to turn it off as a old lady complained about the smoke rotory arm was fine will double check it and the dizzy
:) sketch :)
PostPosted: Sun May 27, 2012 9:03 am
Double check ht leads while your checking dizzy, only takes a bit of an awkward pull on one when changing sparks to damage one.
1998 mercedes E280- sold
PostPosted: Sun May 27, 2012 9:18 am
will double check that too thanks
:) sketch :)
PostPosted: Sun May 27, 2012 5:54 pm
checked both dizzy and leads plus rotor arm seems all fine but have found 2 loose wires to the left hand side of the intercooler ( by the water temp sensor) 1 looks like a earth wire but carnt locate where it goes too any ideas please thanks
:) sketch :)
PostPosted: Sun May 27, 2012 9:41 pm
If its a big earth strap with an eye let on the end it's the main earth. Should go onto the engine mount
If it's got a plastic spade type connector it could be water temp - there are two sensors on the elbow or it might be oil pressure
Does it sound like its cranking faster than usual?
It might be really flooded. If so sometimes you can clear it by pressing the accelerator right to the floor while cranking - this usually turns off the injectors and allows fuel to disperse with enough cranking
PostPosted: Sun May 27, 2012 10:56 pm
its a plastic spade comes off the main loom will double check water temp but that had a plug which conects to the sensor as reguards the elbow not 100%sure where you mean will also give the accelerator idea ago
:) sketch :)
PostPosted: Mon May 28, 2012 12:07 pm
Take a spark plug out to look inside the bores to see if its flooded?
PostPosted: Mon May 28, 2012 6:27 pm
found a wire connceted it to a earth then when trying to start the car the water temp guage in the car went mad ( jumping up and down) diconnect it and it stoped dont know where it connects and is this a possable cause of the non start
:) sketch :)
PostPosted: Mon May 28, 2012 7:45 pm
Possibly but it sounds like something a bit more fundamental to me. Try to fix that and see what happens.
