It is currently Mon Oct 06, 2025 1:18 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36 ... 56  Next
PostPosted: Sun Oct 30, 2011 7:21 pm
Got any details for that ceramic coating? :)
PostPosted: Sun Oct 30, 2011 8:35 pm
this is the stuff, i just used and airbrush and then slowly heatd it up to hle pit set job done :)
http://www.demon-tweeks.co.uk/Search.do ... lack+satin
thay all so do this
http://www.demon-tweeks.co.uk/Search.do ... cermakrome
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sun Oct 30, 2011 10:50 pm
Hmm,
I am intrigued as to how well the black satin sticks. I have a tub of it and a modellers spray set.
IIRc tehy suggest shot blasting the surface with a particular grade of shot and secondly to apply very very thinly.
How hot did you heat it up to? I thought about about bunging it on my BBQ and closing the lid :-)
PostPosted: Mon Oct 31, 2011 12:41 am
i gave it all a good sanding down by hand then cleand it all with asiton as is tells you to. i sude my heatgun as it goes up to 600c so slowly warmed it up to 600c so hoping it will do the job
BRD Page
PostPosted: Thu Nov 03, 2011 9:47 pm
got the head back tonight :) all nice and clean decked and all the valves have been recut and sealed as thay were leaking very bad.
nice new exhaust studs
BRD Page
PostPosted: Sat Nov 12, 2011 5:55 pm
done a bit to the build today, cleaned the exhaust manifolds and the ceramacoted it
all clean then aired brush the ceramacoat on
then I striped my turbo down ready to go and be rebuild again:(
got the cold side of which is easy
as you can see all the impellers are fine.
than striped the hot side of witch it a bit of a pine as it is stuck on tight :( but got it off in the end
will be looking at may be porting the wastage ports a bit bigger
BRD Page
PostPosted: Sun Nov 13, 2011 6:49 pm
not done much to day just got the cold side of the turbo all cleand up and painted ready for when it goes back to gether
BRD Page
PostPosted: Sat Nov 26, 2011 3:45 pm
did a bit today on the turbo head shield, pained it all up with 650c white paint then baked it to harden the pain as it only set rely hard at 2550c
heat shield in the oven :) don’t tell the wife lol
bing when the timer and all cooked
then covered the inside of the shield with a 1250c lagging to help keep the heat down in the engine bay and help keep the heat in the turbo to quicker spool
this is the 1250c lagging wrap I have
cut lagging to shape
then stick in place with 1250c glue
be for gluing in place
after
I then applied a second sheet and this it is finished ready to fit on the turbo and manifold
[IMG]http://i521.photobucket.com/albums/w332/gt4louis/2011-11-26134141.jpg[/IMG
BRD Page
PostPosted: Fri Dec 16, 2011 7:09 pm
finished of the inlet manifold to day
it is up for sale as i wont be using this, im going to be fitting a nice side feed manifold witch im getting next week :) so that keep me bizy ove xmass as it will need to be ported and port mach :)
BRD Page
PostPosted: Sat Dec 17, 2011 6:07 pm
cam cover finished
BRD Page
PostPosted: Tue Dec 20, 2011 9:18 pm
look what i got :)
a nice side feed manifold :) it needs a little bit of moding but not much :) as you can see i can port this out a fair bit
BRD Page
PostPosted: Wed Dec 21, 2011 5:35 pm
ooooo, what's that from, a 162?
PostPosted: Wed Dec 21, 2011 6:32 pm
yes st162 with tvis :) needs a little bit of moding to work but not much :)
BRD Page
PostPosted: Sat Dec 24, 2011 6:00 pm
ok started porting the new side feed manifold to day
as you can see there is a fair bit that can be ported
so started by making the ports bigger
then take any ally out that is in the way of air flow and port marched it to the TVIS plate
pretty much all done just a bit of tiding up to do then paint I white
BRD Page
PostPosted: Sun Dec 25, 2011 10:29 pm
Nice one Louis 8)
