It is currently Mon Oct 06, 2025 1:11 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 56  Next
PostPosted: Fri Apr 29, 2011 5:19 pm
LOL
Sorry to hear it but glad I'm not the only one. I managed to fit the entire head the wrong way round on mine :oops:
Didn't notice til I walked back with the torque wrench in hand
PostPosted: Sat Apr 30, 2011 4:52 pm
big thanks to Dug and Rich for popping over to give a hand :) and its all back together now as it should be :) but we did have a bit of a moment :( the T piece the oil light and pressure gauge come of snapped of in the head :( but after a quick trip to marlins we got a extractor kit and got the bit out the head and juts fitted the oil light switch for now:)
just go to paint inside the air box, but after Rich left we got it all fired up first time and all sounds good  so very happy, just need to get it booked in for mapping now and running in.
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Mon May 02, 2011 10:33 am
a few more finishing of bits
good news tha car past the mot :) and drive great felt nice to drive and pull very well :) now just need to get to mapped ans et up :)
BRD Page
PostPosted: Mon May 09, 2011 9:14 pm
good news the car is now booked in on the 24th for its remap and cam timing set up :)
BRD Page
PostPosted: Mon May 09, 2011 10:04 pm
Tis looking mighty fine with that new clocked setup
PostPosted: Mon May 09, 2011 11:24 pm
Read through the thread at *cough* the other place*cough* looks like a nice project, look forward to hopefully seeing it in the metal at some point in the future.
One possible tip, when you end up remaking those wires that have broken/corroded off, you can get something called self analgamating tape from electrical wholesalers or screwfix. Fantastic stuff, stretch it over the repair like a bit of normal electrical tape and it welds itself together to give a really nice watertight and insulated repair.
(Nothing wrong with your repair btw, just thought it might be useful for people)
PostPosted: Sun May 15, 2011 1:56 pm
done a bit on the car today. now that I have fitted all the intercooler pipe work and am happy with it all, I have now made a new under tray cos the stock 1 wouldn’t fit back in and had lots of holes in from where I had cut it last time to get the pipes to fit,
so I got myself a nice piece if ally sheet
I then made a template witch I forgot to take photos of :(
but then made the under tray
just propped in place to see how it will fit
then cut it all and this is it now fitted to the car
this should help with air flow thorw the rad and engine to help keep it cooler :)
BRD Page
PostPosted: Sun May 15, 2011 2:41 pm
you need air excapes behind the radiator package to raise air flow
like this ones
[img][img]http://img229.imageshack.us/img229/755/underpanel2.jpg[/img][/IMG]
PostPosted: Sun May 15, 2011 3:16 pm
yes and no, if you look at the front under tray of a st185 TTE set up they didn’t have any
BRD Page
PostPosted: Sun May 15, 2011 5:31 pm
How did you fix the undertray in?
PostPosted: Sun May 15, 2011 5:34 pm
it is pined all the way round the front of the bumper and reused some of the stock bolts holes under neth
BRD Page
PostPosted: Sun May 15, 2011 5:37 pm
possible this is a safari, gravel or snow undertray, however if you want to flow more air you need escapes
PostPosted: Mon May 16, 2011 10:11 am
It's true Sunny but compare them side by side, Mixer72's one is shorter, there is a big escape before the gearbox, which is not the case with Cone on ST205
It probably works better with a little flap at the end but it's better than nothing
PostPosted: Mon May 16, 2011 3:15 pm
i understand your point, but i would give the end of the panel a ~1cm long edge 45° down :)
PostPosted: Mon May 16, 2011 3:58 pm
i was thinking about doing that every litte bit helps :)
BRD Page
