It is currently Mon Oct 13, 2025 2:29 am
PostPosted: Thu Jul 09, 2009 7:26 pm
Any one else with Mario's teflon bushing for rear SUBFRAME ?
I was trying to replace mine yesterday, but I discovered this "little" difference: what do you think?
Ciao!
Wolf_Tm
TM 250 enduro 2 stroke
PostPosted: Thu Jul 09, 2009 10:24 pm
Is the car standing on its wheels in that pic?
PostPosted: Thu Jul 09, 2009 10:46 pm
It would look about right if you peeled the existing rubber mount off of it's metal backplate
It's a bit hard to see, is the top flat?
The upper rubber mount is actually a cup kind of thing so it might fit over the top of the new bushing
PostPosted: Thu Jul 09, 2009 11:06 pm
Yes Mate...
Wolf_Tm
PostPosted: Thu Jul 09, 2009 11:13 pm
Don't know... will check soon!
Btw, looking at the epc, there is no rubber mount over the stock rubber bushing...
Thanks...
Wolf_Tm
PostPosted: Fri Jul 10, 2009 12:59 am
It is there in the EPC but it's not obvious
If you look HERE where I stripped the rear subframe there's some shots of the main mounting points with
and without
the washers
part number is
52272-20030 STOPPER, REAR SUSPENSION MEMBER, UPPER
Unfortunately I don't have a picture of the underside to show. It has a stup in the centre which slides over the metal insert in the centre of the standard subframe bushing, then a gap then a ring of rubber which contacts the circular part of the subframe itself
To be honest I doubt if it matters if you remove that washer and use Marios bushings directly against the chassis. The difference will not be very large and you'll only lower the rear (the correct way without buggering roll centres) by 5 or 6 mm
PostPosted: Fri Jul 10, 2009 7:50 am
and without
the washers
part number is
Ok, now I hope I understand what you meant.... would be very difficult even in Italian to explain and understand via Internet! :wink:
Mario's bushings already have nylon cAp for the nylon cUp (like the stock rubber bushing, the lower rubber cUp and the rubber cAp that goes up, against the chassis).
The fact is that, as you told and as seen in my pic, the thickness is different:
yes, I'll lower the rear, that way, but I will also reduce the clearance between the carbon DS (diameter way bigger than stock) and the chassis...
and I already removed a chassis reinforcement, under the handbrake lever, because it touched the DS...
Thanks a lot!
Wolf_Tm
PostPosted: Fri Jul 10, 2009 10:41 am
Here's a quick artists impression of what I think you have
I guess you might have to get some spacers made up to suit
But it might do this
Difficult to tell without seeing pictures of the top of it!
PostPosted: Fri Jul 10, 2009 10:47 am
Yes sure, but only difference is that the rubber OVER the subframe has not the same thickness (as it appears on your draw) of the nylon spacer...
BTW Mario just replied me he's on holiday, and will help asap...
Wolf_Tm
PostPosted: Fri Jul 10, 2009 10:55 am
To me the rubber looks the same size as the bushing
The rubber has a metal backing plate attached though (this is what presses against the chassis) and I think it's this that makes the difference in the thickness
PostPosted: Fri Jul 10, 2009 11:08 am
No no, it's this the problem!!!
They have not the same thickness!
Wolf_Tm
PostPosted: Fri Jul 10, 2009 11:11 am
Ah ok, now I understand your point of view!
there is not any metal plate against the chassis, all you see, and it seems to be divided in two parts, it's all one piece of rubber....
Wolf_Tm
PostPosted: Fri Jul 10, 2009 11:15 am
it may not be obvious but the rubber is stuck on to a circular metal backing plate. You van just see it in the photo and it should be clear in the diagrams
I think you'll need to make up a metal spacer to replicate that so that Marios bush + spacer is the same thickness as the stock rubber bush on its backplate
PostPosted: Fri Jul 10, 2009 11:17 am
Yes, I think this too...
On the ST185 forum someone just wrote that ST185 has lower than ST205 rubber bushing on top... touche' :D
Wolf_Tm
PostPosted: Fri Jul 10, 2009 11:32 am
might be an easy place to create a few mm of extra clearance
