It is currently Sun May 19, 2024 9:02 pm
PostPosted: Fri May 24, 2013 12:14 am
JEMS, the company that built the record breaking Fensport 3S-GTE's have been working on building up the ultimate Ford YB engine. Similar to the engine fitted to the Ford Sierra Cosworth. Finally got a good run on the engine dyno last weekend.....1,010bhp @ 8,500rpm and 1.9bar boost! Not bad for an engine based on the venerable Ford Pinto block :-)
PostPosted: Fri May 24, 2013 9:32 am
Impressive, would be intersting to see what the power band is below 5000rpm though.
probably a laggy beast..
1000:20
2000:50
3000:70
4000:80
5000:412
PostPosted: Fri May 24, 2013 4:32 pm
This looks amazing. When it comes on boost must be insane.
I also note it's using a chargecooler!
PostPosted: Fri May 24, 2013 7:56 pm
I'd say the charge cooler is part of the engine dyno?
PostPosted: Fri May 24, 2013 11:55 pm
Yep you are right, had a chat about this tonight, maybe using chilled water in the system?
