It is currently Fri Oct 10, 2025 6:44 pm
 Post subject: reset ecu on st185
PostPosted: Fri Jul 27, 2012 1:05 am
can you reset ecu on a st185??? if so how??
ST185 266BHP/257FTLB
PostPosted: Fri Jul 27, 2012 1:07 am
Pull out the EFI fuse in the fusebox. Should be marked on the underside of the cover.
PostPosted: Fri Jul 27, 2012 3:21 am
Or disconnect the battery
PostPosted: Sat Jul 28, 2012 10:19 pm
And wait a few minutes before you put the fuse back/reconnect the battery. A rough idle may be the result. Drive the car for a bit, next start should be ok.
