It is currently Wed Oct 08, 2025 7:16 am
PostPosted: Wed Jun 20, 2012 2:07 pm
hi guys. while driving to work this morning i was driving in second gear and decided to be progressive through the gear but a about 5.5k it felt like i hit a wall.
so i quickly dropped the clutch and changed gear. but does anyone have any ideas.
also while im goin i put petrol in the car te other day and the fuel guage is fine but my petrol light stayed on. rrrrg im sick of this car :-)
PostPosted: Wed Jun 20, 2012 3:40 pm
Do you know what boost the car was running?
How much petrol did you put in?
PostPosted: Wed Jun 20, 2012 4:24 pm
the first part will be fuel cut... i would imagine, that seems like a brick wall nearly, the fuel light... ignore it.
My fuel light came on permanently and i ignored it and the bulb died, i dont need a warning light to tell me when im low on fuel.
i think they are your problems
PostPosted: Wed Jun 20, 2012 5:22 pm
It does sound like fuel cut to me as well have you got a aftermarket boost gauge fitted?
PostPosted: Wed Jun 20, 2012 5:43 pm
about 1.15 bar ive had an ebc on the car aince i baught it so figured i had one on ill have to check where is i located? i had about 20£ in thw car and the lifht is on never done anything like thats before light wise
PostPosted: Wed Jun 20, 2012 6:38 pm
20 doesn't buy that much fuel nowadays I'd try filling the tank and seeing what happens otherwise the level sensor is broken.
1.15 bar is almost fuel cut territory. Try turning it down a little.
PostPosted: Wed Jun 20, 2012 7:06 pm
yeah ive turned it down seems to be alright.
saying that mind when i baught the car it was runnin 1.2 bar and it was alright turned it down as i thaught it was a little high . where is the fcd placed ill need to check.
the profec b im running is set to warn after 1.2bar so i wonder i i should knock it down a bit.
also where is the sensor is located a ill see if i need to replace it.
it was my last £20 i dont get paid till friday :-(
PostPosted: Wed Jun 20, 2012 7:27 pm
it wont just cut on 1.2bar, many factors seem to alter the boost cut, and ebc are not 100% accurate, mine sometimes used to cut at 1.1 and others it would allow an over boost to 1.25 according to the blitz ebc.
set the warn to 1.15, what cooling do you have? the charge cooler?
and it costs about £80+ to fill a tank so indeed 20 will only just get out the red zone but also if the sensor is bust i wouldnt bother fixing it, mines been bust for over a year.
dont touch a fcd, it WILL kill a 3s
PostPosted: Wed Jun 20, 2012 9:24 pm
ok i will do. yes i just have the charge cooler.
what do you mean about the fcd whats a 3s (not sure if its a daft question)
will it be eaay to get hold of a new sensor?
PostPosted: Wed Jun 20, 2012 11:01 pm
3s is our engine code.
The fuel cut defender i thought you meant that you had a HKS fcd in which you can alter when the fuel cut will occur which will make the engine go bang.
The fuel cut for the car is programmed into the ecu, it just saves the engine from damage so is a good thing to make sure isnt messed with.
Pull out the pump with the sensors attached, im sure that the sensors wont be much, as i say i have never looked into the fuel level sensor as it never bothered me enough to fix it.
Deffo lower the boost warning to 1.15 or so on the charge cooler, not the best for sustained boost. :)
PostPosted: Thu Jun 21, 2012 6:30 pm
cut down the boost warning and decided to do an ecu test ive got a code 52 knock sensor.
how fatal is it as ive had a quick look and there about 80 qwid i dont have the money atm or is anyone selling one ???
PostPosted: Thu Jun 21, 2012 6:49 pm
i have one on the back of my spare block if i can get to it, its buried deep at the back of my shed, where do you live?
You should in theory be ok to drive the car as long as you are not smashing it, as det and knock dont seem to happen under low load and no boost
PostPosted: Thu Jun 21, 2012 7:07 pm
i live up in newcastle mate. how much would you want for it? im going to see if it ces on again on my drive to work tomorow. it may have just took a funny turn.
PostPosted: Thu Jun 21, 2012 9:38 pm
my knock sensor went and all it was the cable had come loose (heard on the oc this was common) saved myself a few pennies...be warned though it is a nightmare to get to!
PostPosted: Thu Jun 21, 2012 10:14 pm
anyone got a pic of where it is ?
