It is currently Mon Oct 06, 2025 10:15 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: exhaust fitment
PostPosted: Sat Oct 06, 2012 11:04 am
hi guys,i have a hks silent hi power ,just had a mate at quickfit put it on,had to remove the corner of the rear subframe to get it not to hit :( ,also even with all that done it still hits the bolt where it comes out from it too :( ,rubbers all seem good condition,what rights do i have refund swap ect?.
was brougt from sumo power.
wish i had chose the blitz now :(
cheers
PostPosted: Sat Oct 06, 2012 3:06 pm
Is this the 3inch?
 Post subject: exhausts
PostPosted: Sat Oct 06, 2012 4:17 pm
yeah,all the posts ive read say it fits really well ect.
PostPosted: Sat Oct 06, 2012 5:23 pm
I've never seen a 3inch fit well lol there just ain't enough room for them.
PostPosted: Sat Oct 06, 2012 6:20 pm
agreed, its going to knock somewhere if its 3" (mine does)
mind you, some suppliers sell it as a 2.75" exhaust. Sure its 3" though
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Sat Oct 06, 2012 6:38 pm
hks site and sumo power all say 75mm,just sent them an email about the problem as its not fit for purpose ect.
PostPosted: Mon Oct 08, 2012 4:50 pm
They all have a tendency to rattle unless fettled
I find that I have to spend quite some time to get it right. Undo all the bolts everywhere and twist the rear section until you have clearance everywhere. Bending of brackets is sometimes required
Does it rattle in any specific situation?
PostPosted: Mon Oct 08, 2012 7:19 pm
My 75mm Blitz Nur SpecR system fitted really well, no rattles at all :D Would recommend it.
PostPosted: Mon Oct 08, 2012 8:17 pm
Same with my HKS (185), dunno why others have so much problems..
PostPosted: Mon Oct 08, 2012 10:24 pm
My blitz nur rattled. Possibly it depends what hodge podge of components live upstream. In my case much Aussie equipment with non OEM turbo
Even the bespoke H&S rattles if I don't line it up right when swapping downpipes
PostPosted: Tue Oct 09, 2012 12:04 am
My Blitz was fitted to an OEM front pipe and cat/downpipe originally then a 3" Hayward & Scott downpipe and front pipe. I outsourced the fitment in each case so maybe that made the difference ;-)
PostPosted: Tue Oct 09, 2012 10:28 am
its hitting the rear diff crossmember, aswell as part of the subframe itsself,on the bend before the flange.
PostPosted: Tue Oct 09, 2012 12:28 pm
i have some photos of what is going on,the guy also had to mount the lower rear diff crossmember on washers to try and gain clearence or the exhaust would not have fitted at all :/
PostPosted: Tue Oct 09, 2012 6:20 pm
What do you have as a the front section of the exhaust, it doesn't look OEM.
PostPosted: Tue Oct 09, 2012 9:23 pm
the whole system started off completely standard,even had toyota stamped on the rear tailpipe when they took it off to fit the hks,only mod thats been done was a Hayward and Scott 100 cell race cat that basically is a ss copy of the bottom section of the cat housing,it mated up to the front pipe spot on when i fitted it.The front pipe has all the original heat shielding around it ect so in my opinion i think its as standard as the rest of the system,cars only done 52k so to me it seems about right.
