It is currently Mon Oct 06, 2025 4:25 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Oct 24, 2006 1:30 pm
hmmm- I dont knwo a great deal about this whoel linering ting but:- it must be a right PITA converting a block to "wet liner" type - just machining out the block woudl surely craete a whole world of pain in trying to then ensure the liners sealed in teh water galleries again to stop the water just flodding into the sump? Maybe I am over complicating things ;-)
PostPosted: Fri Nov 24, 2006 8:18 pm
I have produced a word document to assist searching for replacement 3sgte forged pistons. alas i cannot upload it here :?
# Double check your intended ebay purchases / part numbers carefully to ensure correct compression ratio.
# Note there appears to be some confusion with certain brands between old and new part numbers for the 3sgte and 2jzgte pistons.
# Observe the relationship between Dome CC + CR + intended gasket thickness and deck height etc.
external link to word doc
>>>> please feel free to copy the word.doc and host here as appropriate.
hope that helps
some links:
Manufacturers websites:
http://www.accralite.com
http://www.ariaspistons.com/catalog/ARIA2006cat.pdf
http://www.ariaspistons.com/toyota.html
http://www.cppistons.com/PDFs/Sport%20C ... actpdf.pdf
http://www.jepistons.com/pdf/2006-sportcomp3.pdf
http://www.jepistons.com/cat/je/sport/t ... sgte.shtml
http://www.rosspistons.com/uploads/toyota_3.pdf
http://www.wiseco.co.uk/_private/Compac ... sc-toy.pdf
http://www.wiseco.com/PDFs/Catalogs/SC06_Toyota.pdf
Suppliers:
http://www.horsepowerfreaks.com/perform ... ine/Piston
3s-gte pistons on ebay
3sgte pistons on ebay
ST165 turbo 4WD
PostPosted: Sat Nov 25, 2006 12:39 am
Sorry, but only users granted special access can read topics in this forum.
If you mail it to me I'll host it for you if you like.
PostPosted: Sat Nov 25, 2006 1:23 am
Thanks, and here you go.. :D
(I've added Jun and HKS too btw, shame on you to forget those :lol: - I'll convert it into a nice readable page on my site)
http://www.turbocelica.nl/docs/forgedpistons.doc
PostPosted: Tue Nov 28, 2006 10:03 pm
JE have revised there 86.5mm 9.0:1 3s-gte pistons to part number 252061,
the difference being smaller ring widths...
anyone geting these make sure you get the correct rings part # JG1004-3405, as keith and I have had a load of grief sorting this one out..all sorted for now though :D
Pete
ST185
Basingstoke
PostPosted: Tue Nov 28, 2006 10:37 pm
Thanks Pete, first post amended with this new info :)
PostPosted: Sat Jan 27, 2007 1:34 am
http://www.horsepowerfreaks.com/sale/Br ... Shelf/pg/2
:? appreciate some asistance please.
doe anyone have experience or knowledge of "Brain Crower" CP pistons?
Toyota Celica 3SGTE - 86.5mm Bore, 8.5:1 #249646 $560.83
Toyota MR2 3SGTE - 86.5mm Bore, 8.5:1 #249648 $560.83
thankyou.
ST165 turbo 4WD
PostPosted: Sat Jan 27, 2007 2:06 am
strange one that...the only reason for different part numbers is to obtain the correct CR as far as i can think.
as far as i know usdm celica alltrac headgaskets are 1.4mm. But alot of MR2 talk is that there gaskets are 1.0mm, maybe the pistons are different to obtain the 8.5:1 cr raito as stated between engines?
if you can find an email for them, it may be worth dropping them a line direct to find out?
Pete
ST185
Basingstoke
PostPosted: Sat Jan 27, 2007 9:43 am
morning Pete.
cheers for the reply. i've sent several emails to horsepower freaks over teh last 2 weeks. getting info or assiatance from the sales department is like try to extract blood from a stone
:twisted:
ST165 turbo 4WD
PostPosted: Mon Dec 03, 2007 9:59 am
An interesting article on varying types of pistons
http://autospeed.com/cms/A_109229/article.html
PostPosted: Tue Sep 18, 2012 1:05 am
bit of a resurrection on this but it should be noted if you bore and hone your cylinders properly with the new generation of low expansion alloys available you can't run a 86.00mm piston as Toyota relax bore there engines, which mean they oval with the stresses a torqued down head creates. If you use a torque block when boring and honing like all educated engine builders should using a clearance hone for a forged 86mm piston won't remove the oval you need to go to a 86.25mm piston to get the bores perfectly round. Not many places make these but I commissioned CP Pistons to make custom pistons for me to use in that size. And use those all all my high bhp builds.
Just a bit of piston - engine building information
Tim
TB Developments
PostPosted: Tue Sep 18, 2012 10:23 pm
Thanks Tim for sharing the info.
PostPosted: Wed Sep 19, 2012 12:12 am
do what i can :)
