It is currently Mon Apr 29, 2024 4:06 pm
PostPosted: Fri May 31, 2013 8:57 pm
Thought some of you may be interested in this.
Decided to sacrifice my clock and install an Arduino-based microcontroller in its place, primarily to allow accurate measurement of the effect of aerodynamic modificaitons I have planned for the future via the monitoring of fuel consumption while at a constant speed.
Bit of background on Arduino: http://en.wikipedia.org/wiki/Arduino
My install:
I tried to get it looking like it belongs.
Aside from the various outputs related to fuel consumption It can display standard stuff such as speed/distance, rpm, voltage & 400m time/trap speed, and will be as accurate as the VSS signal resolution allows so far better than any GPS-based unit.
Pretty much finished calibrating it now.
Unrelated to the above here is a shot of my stealth oil temperature & boost gauges :p
PostPosted: Fri May 31, 2013 9:10 pm
Very nice indeed! Scale of the boost meter is still useless though?
PostPosted: Fri May 31, 2013 9:17 pm
It is if you don't know what those dashes and dots correlate to ;)
PostPosted: Fri May 31, 2013 9:22 pm
I started a similar thing about 3 yrs ago.... Not quite finished it. But that's par for the course at my speed doing things on my car !
Never thought about locating in the clock hole. I was going for the spare slot with the stereo. But a larger 20x4 screen being about 145mm wide.
Darryl
Darryl
PostPosted: Fri May 31, 2013 10:28 pm
I thought about something like this nearly 10 years ago
Not quite started it yet. That's about par for my rate of progress :lol: :oops:
Users browsing this forum: No registered users and 165 guests
