It is currently Sun Oct 12, 2025 5:43 am
PostPosted: Mon Feb 20, 2006 4:04 pm
Hi ya guys i wonder if any one can help me i fitted a sard R2D2 dump valve to my 185cs, and i can't get it to dump. I've read that there can be problems with 185 and dump valves, so if any one has any ideas that would be great.
PostPosted: Mon Feb 20, 2006 4:10 pm
The issues with ST185's and dumpvalves are mainly around fueling. The valve should operate regardless.
Have you plumbed in the vacuum line correctly? Which line did you use?
PostPosted: Mon Feb 20, 2006 4:47 pm
Well with out sounding like a plum, i'm not sure a couple of mates help me and they have fitted quite a few to other cars and they seem to be stumped. i can tell you wat it look like it was at the back of the thottle housing there was a round thing that look like a really old dv or maybe a fuel reg but not sure put a t-pice in to that line, we did try a couple of other ones but didn't get anything.
PostPosted: Mon Feb 20, 2006 6:32 pm
Willbo01 - I take it you connected the DV into the traditional location between the turbo and the Intercooler?
Also, the pipe that comes the DC should be fitted after the throttle body i.e. on the engine side of the throttle body.
You should avoid using the fuel pressure regulator pipe at all costs! I would humbly recommend leaving that well alone.
PostPosted: Mon Feb 20, 2006 7:10 pm
Wilbo - YOu may finds that the item you tapped into was infact the EGR valve (only on Uk supplied vehicles and looks similar to a dump valve or fuel pressure regulator. http://www.gtfours.co.uk/pics/egr/egr.jpg linky from gtfours website courtesy of Kris :-) ) IIRC this takes a vacuum feed from some of the ports on top of the throttle body and not after the throttle plate.
IMHO if you have a ST185 tap into the turbo pressure sensor vacuum line for the dump valve.
DO NOT DO THIS IF YOU OWN A ST205 THOUGH! the ST205 uses the sensor to determnine fuelling.
PostPosted: Mon Feb 20, 2006 7:16 pm
If you take a look at my website under my four is some images I took of where I fitted my dump valve. http://jamjar.harbourlight.uk.com
Hope that helps,
Tone
Now offering:
PostPosted: Mon Feb 20, 2006 8:25 pm
And to add a little bit more spam: http://www.turbocelica.nl/how2bov.htm
In the pic on the bottom of that page you see the 8 mm vac point on the side of your TB, works well!
PostPosted: Mon Feb 20, 2006 8:46 pm
ooh yes - forgot about teh big 8mm jobbie on the ST185. Apparently this will provide a better and more accurate signal as it is a larger bore pipe.
PostPosted: Tue Feb 21, 2006 1:59 pm
i just want to say thanks for all the help guys, the pictures i think will help a lot, so i will give it a go tomorrow morning before work and see if i can sort it out and i'l let you know
cheers again
