It is currently Sun Oct 05, 2025 4:04 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 41, 42, 43, 44, 45, 46, 47 ... 56  Next
PostPosted: Mon Mar 18, 2013 10:23 am
i think your car would look better if the bonnet was red, dont like the odd coloured bonnet "taxi" look. It would suit the new look better too, although i think the roof needs something.
PostPosted: Sat Apr 27, 2013 6:07 pm
ok had a good day with the help of Rich fitting the new racing graphics to the beast
so got the graphics throw
then the fun started :)
PostPosted: Sat Apr 27, 2013 7:36 pm
looking great Louis :D
Just in time for Japfest :D
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Sun Apr 28, 2013 9:29 am
PostPosted: Sun Apr 28, 2013 10:33 am
Just need to change your profile pics now :D
Hybrid turbo
Apexi AVC-R
PostPosted: Mon Apr 29, 2013 4:47 pm
finished the graphics of today rely happy with look
PostPosted: Mon Apr 29, 2013 7:07 pm
Not something I would do to mine but I do think that looks pretty good!
PostPosted: Wed May 01, 2013 11:55 am
all waxed and ready for japfest :)
PostPosted: Mon May 13, 2013 9:45 pm
The Beast at Japfest
http://youtu.be/QrOaJBrMVMY
PostPosted: Mon May 20, 2013 6:14 pm
took some more of the sound deadening out today and fitted new under plates for the rollcage
still more to come out but getting lighter
PostPosted: Mon May 20, 2013 10:17 pm
Good to see you following Colin Chapman's advice of 'adding more lightness' :D
PostPosted: Mon May 20, 2013 10:26 pm
still have more to come out from the rear and any bits on metal I can get rid of as well :)
PostPosted: Mon May 20, 2013 10:43 pm
I got rid of most of the double skinning on mine and drilled loads of lightening holes but I wasn't sure how much scope you had for this with a bolt-in cage. My shell was pretty flimsy once I'd done all of that but it didn't matter so much as I have a full weld-in cage which is almost a spaceframe chassis :mrgreen:
PostPosted: Fri Jun 14, 2013 12:50 pm
PostPosted: Fri Jun 14, 2013 12:51 pm
bit of an update been bizy turning the stock sump into a baffled sump
as some of you know the stock st185sump is not very good for track use as there are no baffles in it so help stop oil starvation, this is what the stock sump looks like under the top plate, as you can see it needs some baffles to help stop oil starvation, so guess what I’m doing to be doing it :)
here are some photos of the sump so far
first drill out all the stop welds holing the top plate in
here you can see just what is under the top plate
as you can see not much there to stop the oil from sloshing around and getting oil starvation
this the top plate
again nothing to stop the oil starvation
so after a good clean its ready to have the baffles fitted
got 1 more to fit at the top end
just 1 more baffle to finish off and fit
finished of the baffled sump to day
and I have all so added a crank breather to the sum to help get rid of the crank pressure
just need to give it all a good clean and paint the out side of the sump and it can be fitted
