It is currently Sun Oct 05, 2025 8:04 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40, 41, 42 ... 56  Next
PostPosted: Sun May 06, 2012 7:41 am
Also, with the ecu supply being low,there must be a lower threshold at which it no longer functions.before that, are the ecu outputs just artificially low also as theyre derived from the low 11v supply? This would in turn, cause sensor feeds into the ecu to be inaccurate?
PostPosted: Sun May 06, 2012 7:09 pm
The internal electronics normally runs at 5V with an internal regulator which will run down to about 7.5V in. Sensors are normally fed from this 5V supply so will be accurate.
The main problem is that the injectors are driven from the +12 (actually +14 ish normally) and the speed of operation of injectors (dead time) is proportional to voltage. If the voltage is low, the mixture will go weak as the injectors will be slower to fire. The ECU should have correction for this but it isn't 100% accurate so mapping should take place at the full operating voltage.
As an aside, you need to be sure the injector feed is also good in in fairly heavy gauge wire to minimise voltage drop. The most important thing is that the ECU & injector feeds should be the same voltage so that the ECU corrects for any drop in voltage. Failure to do this could result in a fried engine.
PostPosted: Sun May 06, 2012 7:20 pm
it was just the feed to the ecu that was low, i have fitted new feeds now with inline fuse to keep things safe, so every thing should be ok now, just goto get it back and get it mapped ready for japfest saturday
PostPosted: Tue May 08, 2012 12:24 am
just got back from having the beast mapped :) and all I can say is O MY GOD it quick won’t know what power it is pushing till it on the dyno in a few weeks time to tweak the map, but I’m very happy bring in japfest
PostPosted: Tue May 08, 2012 5:59 am
Nice one buddy, i can't wait to have a look around it at japfest :)
PostPosted: Sat May 12, 2012 10:19 pm
well first time out on track after the build and I’m well happy :) the car ran rely well and boy does it handle good :)
http://youtu.be/rRTF4Sq2KDY
PostPosted: Sat May 12, 2012 11:29 pm
Sounds good! Nice vid.
ST185 CS #1845
PostPosted: Sat May 19, 2012 6:40 pm
done a few bits to the car today. first I flushed then bled all the brake system with AP 600 :)
then I relocated the oil cool
here you can see were to oil cooler was before
not much room for the air to get to it.
here it is now in its new home
just go to plum it back in tomorrow :) I’m all so looking at fitting a small fan on the back of the oil cooler
PostPosted: Sat May 19, 2012 8:02 pm
You really "Macgyverd" that in there with ducktape. :D
I'm sure you will securely mount that. Any Idea when your going to the dyno?
ST185 CS #1845
PostPosted: Sat May 19, 2012 9:55 pm
the ducktape is only there to stop the air flowing under the oil cooler, itsi all bolted and straped in nice and tight :)
PostPosted: Sun May 20, 2012 12:06 am
Have you measured your oil temps? I doubt that you will need a fan as well.
PostPosted: Sun May 20, 2012 9:18 am
Sorry but : i would never installed the rad upside down
how many rows will contain oil ? how many rows contain air ? how to bleed the rad ?
It's nice for service but you waste 50+% utility
And having use this place with a 13 rows before you don't need a fan, just take care of ducting the air as much as you can. If oil doesn't go too high it doesn't need to be overcooled
PostPosted: Sun May 20, 2012 11:03 am
i can only fit it this way round as there isent room the other way to get the take off pipe in, the fan was just an idea.
PostPosted: Sun May 20, 2012 12:06 pm
try loosing those fittings and use banjo bolts instead , u will get some room
PostPosted: Sun May 20, 2012 5:55 pm
Did Toyota get it wrong as well by mounting the gearbox oil cooler 'up-side down' too?
I was always lead to believe Toyota spent the most money in R&D!?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
