It is currently Mon Oct 06, 2025 1:16 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 29, 30, 31, 32, 33, 34, 35 ... 56  Next
PostPosted: Tue Oct 18, 2011 2:34 pm
to be fair many people get extremely good power from the stock manifold, yes you would get more out of aftermarket but why bother when you can get 500bhp out of the stock and you know it wont crack. makes sense to me to keep it in one peice
PostPosted: Wed Oct 19, 2011 10:15 am
Mostly I'd bother because you can get free power while making a safer engine!
The stock manifold is OK but the standard line that it's fine up to 6,000,000HP is just bunkum
It works certainly but the unequal runners and generally restricted flow are not doing the engine any favours!
PostPosted: Wed Oct 19, 2011 11:04 am
too true but when does it become a necessary item on a road car that sees the track?
what im saying is if you can get power out of the stock unit and staying the safe side of reliable rather than going for a flashy looking manifold that will crack all the time just for the sake of a few ponies and less reliable part surely doesnt make too much sense on a road car?
no questions that a tubular is better, hell we all know that but at what point does the stock unit deemed obsolete?
PostPosted: Wed Oct 19, 2011 11:50 am
Not all aftermarket manifolds will crack
However, cheap rubbish off ebay is guaranteed to have more crack problems than a LA drug den
When to fit one is more difficult. If all you can afford is ebay then never. If you can afford a decent/bespoke item then pretty early in the mods process in my book
PostPosted: Wed Oct 19, 2011 12:01 pm
hmmm, interesting... you may have changed my mind with regards to them then..
however your line with regarding the problems, that certainly made me laugh!! hah :D
money is not particularly a problem, and i like one off items hence the one off mid sections from Tim, but what knind of size etc is good? i have never looked into manifolds really
PostPosted: Wed Oct 19, 2011 12:43 pm
Or u could just do like i have and port polish and port match i know of gt4 runing 700bhp on stock manifold but im only going for 400bhp and a bit better spool up. if u look at the photos of my msnifold ur see.
PostPosted: Wed Oct 19, 2011 7:55 pm
yes i see you have done a fantastic job there mixer!!
if i ever pull mine apart i shall think of doing so also
PostPosted: Wed Oct 19, 2011 11:14 pm
two_OH_five wrote:
Not all aftermarket manifolds will crack.......
List of suppliers please Steve...... :D
I acknowledge there are a few cast aftermarket manifolds available so I'm sure they would probably be unlikely to crack. Fabricated tubular manifolds won't be as strong so they are more likely to crack. One of the things which have been tried recently on Formula Ford 'Kent' engines to reduce the chance of cracking is to fit an exhaust manifold facing plate which joins all four of the exhaust runners. Any support you can give the runners and/or manifold would be a benefit. Witness the OEM support struts between the block and turbo/manifold. Most people leave the support struts off if they decat and fit a hybrid turbo. Probably not a wise move although I've been guilty of this myself in the past :oops:
PostPosted: Thu Oct 20, 2011 7:30 pm
stock manifold isnt all that . ive seem them cracked and the gasses from cylinder 2 flow right over the port of cylinder 3 on the way to the collector , not seperate at all . ( st205 wrc manifold )
PostPosted: Fri Oct 21, 2011 6:28 am
I’ve had 2 185 manifolds crack across the top of 3 and like Don said all the support brackets are important, the key is to assemble the manifold and down pipe in a neutral stress position, although not a guarantee to stop cracking it certainly helps to reduce it. Dorris
Black CS 2771
PostPosted: Sun Oct 23, 2011 4:01 pm
got a lot done today :) engine and box out the car.
lowerd every thing out the bottom
as you can see halford do come in handy some time :)
PostPosted: Sun Oct 23, 2011 4:04 pm
IMG]http://i521.photobucket.com/albums/w332/gt4louis/2011-10-23115953.jpg[/IMG]
im shoer ther sould be something in here?
then i split the box from the engine :)
all so clead up all the pistons and getting read to fit the polly bushed into the engine mounts
PostPosted: Sun Oct 23, 2011 10:37 pm
Good to see you have made progress. Interesting pic diary. You must be glad the weather held this weekend!
PostPosted: Mon Oct 24, 2011 6:26 am
very happy that the weather help :) that y i pushed on with it to get it all out:) i can now do all the rest of the work in my work shop nice and warm :)
PostPosted: Sun Oct 30, 2011 5:43 pm
done a bit more today cleaned the hot side of the turbo up and then ceramic coated it to help keep the heat in and help it spool up a bit quicker
turbo be for ceramic coated
turbo after i have ceramic coated it all :)
just go the exhaust manifold to do :)
