It is currently Mon Oct 06, 2025 1:16 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 56  Next
PostPosted: Sat Oct 15, 2011 9:23 pm
I then did some more porting and polishing to the exhaust manifold
PostPosted: Sun Oct 16, 2011 9:21 am
Louis, is the turbo you're using twin-entry? If not grind out that central bridge between the two ports to make it single entry.
PostPosted: Sun Oct 16, 2011 9:28 am
yes mate im using a hybrid ct26 witch still has the twin-entry
PostPosted: Sun Oct 16, 2011 9:47 am
Ah right. Have you thought about fitting a quick spool valve then to get low end response:
http://www.spracingonline.com/store/Sound_Performance_Quick_Spool_Valve/3643
http://www.youtube.com/watch?v=_KNLKVgg8po
PostPosted: Sun Oct 16, 2011 11:27 am
did look at this but it would work with the ct turbo as youi wiil be blocking flow to the turbo for 2 of the exhuast runners
PostPosted: Sun Oct 16, 2011 2:52 pm
been busy again today, gave all the crank cap ends a good chemical clean and they look much better now :)
just wondering what are the numbers on the ends of the caps?
all so finished port matching and polishing the exhaust manifold,
all that needs doing now if to have to ceramic coated to help keep the head down in the engine bay and it will help spool the turbo up a bit quicker
PostPosted: Sun Oct 16, 2011 3:31 pm
wow, did you used any kind of flexible tool on the manifold?
PostPosted: Sun Oct 16, 2011 5:03 pm
i got a flex bit that goes on to the end of the dremel so that i could get as far into the manifold as a i can
PostPosted: Sun Oct 16, 2011 7:38 pm
loking good that mate. :)
PostPosted: Mon Oct 17, 2011 1:02 am
Shirley with a twin entry manifold all that's going to do is
1) Completely cut off 2 cylinders
2) Severely restrict all 4 cylinders
PostPosted: Mon Oct 17, 2011 6:19 am
this will only work if you have a sigle entry turbo it will help spool quicker as the all the air is forced in to 1 place and this makes the air go quicker. witch make the turbo spool faster
PostPosted: Mon Oct 17, 2011 5:37 pm
great, never thought that such a tool is available :lol:
PostPosted: Mon Oct 17, 2011 10:52 pm
But even if you've got a single entry turbo on a twin entry manifold I can't see it working. It will choke two cylinders
The only benefit I see is a twin entry turbo on a single entry manifold
PostPosted: Mon Oct 17, 2011 11:35 pm
I’m with you on this one just cant see how it will work on both single or twin entry, like you say either way it is shutting off the gas flow from 2 cylinders unless there is a bypass from all 4 cylinders to 1 side of the entry to speed up gas velocity then cant see the point. Dorris
Black CS 2771
PostPosted: Tue Oct 18, 2011 12:13 pm
Yes it requires a twin-entry turbo, and you can open up the twin entry manifold by removing the bridge and blending the bowl which will effectively turn it into a single entry item by allowing all 4 runners to merge prior to the valve. It's not ideal, but if you're still using the stock manifold you're running far from ideal anyway!
