It is currently Mon Oct 06, 2025 3:20 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31 ... 37  Next
PostPosted: Wed Dec 12, 2012 11:26 pm
does anyone know where i can get a stainless 14mm banjo adapter with banjo bolt M14x1,5?
PostPosted: Fri Dec 14, 2012 1:39 pm
hard to find but here it is
http://www.ebay.at/itm/400281782929?ssP ... 3599wt_929
PostPosted: Wed Dec 19, 2012 9:06 pm
hopefull the last revision to the fuel system
i'am just pending about i should use the damper
PostPosted: Mon Dec 31, 2012 5:23 pm
looking good mate what you got planed next?
PostPosted: Tue Jan 01, 2013 8:55 pm
and thanks
tomorrow i should get the new cam gears, then come the water lines of the turbo
or on less words a whole of little works are still to do
PostPosted: Tue Jan 01, 2013 9:04 pm
I keep meaning to say
I think the fuel return line needs a mechanical fixing to stop it vibrating. The thought of it wearing through from vibration is not a good one
Is the speedway bike yours?
PostPosted: Tue Jan 01, 2013 9:50 pm
the pictures are not the best but there is space around the line, so that no contact is possible
thats my friends bike which is the ower of the garage
PostPosted: Wed Jan 02, 2013 3:02 pm
the new gears are here
a comparison to the old ones
the gears are great,
- 10mm head against a allen key
- granate pin
- two further wholes for a key to turn the camshaft
love them, hope they fit :lol:
PostPosted: Wed Jan 02, 2013 6:12 pm
corrently i'am quite not happy with the timing belt tension, or possible it is correct, but can anyone give me a tip how much tension i need?
PostPosted: Wed Jan 02, 2013 8:39 pm
This is set by the hydraulic tensioner.
If you have just fitted the belt, turn the engine over by hand and that should apply the correct tension across the belt and components
PostPosted: Wed Jan 02, 2013 10:27 pm
i did a bit of part number comparison and found that i possible have the wrong tensioneer idler pulley
the issue is that i use the smaller gen.3 oil pump gear and the gen.4 uses the bigger one
possibible here is the problem.....
PostPosted: Thu Jan 03, 2013 6:53 pm
iirc there is a one tooth difference between Gen 3 vs Gen 4 cambelt length...
PostPosted: Thu Jan 03, 2013 7:04 pm
thats from gen.2 to 3 :)
i got the problem, today i did a search for a old gen.3 idler and mounted it to the engine, now i have enough tension, have to pay another € for that but better then a engine death :)
do you possible has some pictures of an 3S-GTE with mounted gearbox especially the water outlet area?
need them for a better sight of thing in front of the coolant line routing for the turbo :)
PostPosted: Thu Jan 03, 2013 10:09 pm
205 WRC engine
PostPosted: Thu Jan 03, 2013 10:29 pm
Hi Kris,
thanks, but my engine stand show me the same :lol:
i'am just not sure how much space i have to the gearbox, i will route the coolant line with a 120° AN10 fitting under the big water outlet hose.....if possible
