It is currently Mon Oct 06, 2025 5:09 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 37  Next
PostPosted: Sun Nov 25, 2012 5:21 pm
[img][img]http://www.abload.de/img/20121125_164337ccob6.jpg[/img][/IMG]
[img][img]http://www.abload.de/img/20121125_1643452dprh.jpg[/img][/IMG]
and tomorrow i will weld it
PostPosted: Tue Nov 27, 2012 10:16 pm
the manifold is ready, the job was a little paine of work, high temp cracks on the welding and pretty hard to deck, but all in all ready to mount/ test fit
[img][img]http://www.abload.de/img/manifold176smg.jpg[/img][/IMG]
[img][img]http://www.abload.de/img/manifold2ocswf.jpg[/img][/IMG]
[img][img]http://www.abload.de/img/manifold3g7smy.jpg[/img][/IMG]
PostPosted: Wed Nov 28, 2012 6:23 am
Nice work :)
GT Four Adovansu
PostPosted: Wed Nov 28, 2012 2:40 pm
thanks man, and here the first mounting
hte new engine also uses a new oil thermostat which also have sensor ports to safe some space down to the undertray
PostPosted: Wed Nov 28, 2012 5:31 pm
looking good mate what turbo you using again?
PostPosted: Wed Nov 28, 2012 6:24 pm
Sunny - where did you get that oil cooler take off plate? It looks interesting.
PostPosted: Wed Nov 28, 2012 6:47 pm
be careful when mounting the gearbox, you will probably have to grind some material off where the turbo "interfaces" with it :)
PostPosted: Wed Nov 28, 2012 7:12 pm
Hi folks,
mixer72, Borg Warner EFR6758
Sirius, from greedy great part except the price :lol:
http://www.shopgreddy.com/accessories/e ... 16unf.html
andycaca, thanks for the tip, i hope that i do not get a problem, i'am behind the line of the block where the gearbox mounts, hope you understand what i mean, sry my english could be better....
any tips where i can get stainless 14mm banjos and M14x1,5 banjo bolts?
PostPosted: Thu Nov 29, 2012 2:22 pm
doesn anyone know how much degree angle the 3S mounts in the engine bay?
PostPosted: Thu Nov 29, 2012 7:39 pm
if you havea look at my engien bay the block lean back not shore by how much
PostPosted: Thu Nov 29, 2012 7:44 pm
i think the IC must have the same angle as it looks straight once the engine is mounted
PostPosted: Sat Dec 01, 2012 7:40 pm
der IC is raised 14mm to get space for the cops
and here the ic pipework issue
[img][img]http://www.abload.de/img/ic1xnq5w.jpg[/img][/IMG]
PostPosted: Sat Dec 01, 2012 8:41 pm
Would it not be better to fabricate your own charge cooler from scratch?
PostPosted: Sun Dec 02, 2012 1:37 am
this was a option too, but isn't cheaper and here in austria in front of the laws i would like to have (nearly) a OEM look to be a little bit safe from controlls
PostPosted: Sun Dec 02, 2012 10:25 am
just say FMIC was factory option? ;)
but in reality, it looks like youll have to make 2* 45 degree takeoffs to use a straight bit of silicon hose. unless you somehow find a piece of the right bend to fit straight on (not likely imo)
