It is currently Mon Oct 06, 2025 8:27 pm
Post new topic Reply to topic  [ 401 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27  Next
 Post subject: Re: Track Weapon Chassis
PostPosted: Sun Jul 20, 2014 7:33 pm
I can help you with that.. :)
PostPosted: Mon Aug 11, 2014 4:16 pm
I have read the whole thread before , but cant remember what your intentions were .... are going to race it in a series , or do sprints, or just trackday fun.
PostPosted: Mon Aug 11, 2014 10:05 pm
Hiya, the car is eligible for a number of different categories. It's been built as a circuit racer but could also be used in hillclimbs. I don't have any particular series or championship in mind yet.
PostPosted: Sun Oct 26, 2014 12:54 pm
MoTeC PDM Installation
The MoTeC PDM replaces conventional relays, fuses and circuit breakers by providing electronically switched power to the various electrical systems in the vehicle, including motors, lamps, ECUs and data systems. This simplifies wiring and switch requirements, while increasing reliability.
The PDM30 has 16 inputs, 22 x 8 Amp and 8 x 20 Amp outputs. We did originally try and squeeze everything onto a PDM15 but there wasn't enough channels for what we wanted to do.
Key Features of the PDM are:
• Each output is over-current, short circuit and thermal overload protected
• Outputs are programmable in 1 A steps
• Outputs are controllable via a combination of switch inputs, CAN messages and logic functions
• Switch inputs are ranging from 0 to 51 V, resolution 0.2 V
• Performing up to 200 logic operations using operators like Flash, Pulse, Set/Reset, Hysteresis, Toggle, And, Or, Less than, Greater than, Not equal to, Equal to, True, False etc.
• Performing functions such as flashing indicator lights and controlling thermo fans and fuel pumps
• Using logic functions to selectively turn off systems during low battery voltage or engine starting, reducing drain on the battery
For anybody interested in reading more the user manual link is:
http://www.motec.com/filedownload.php/P ... docid=2434
MoTeC CAN to USB converter. This allows you to connect a laptop to the vehicle electrical system and make changes to the config on the fly or simply monitor 'stuff'. This is really essential if you want to have a go at changing the configuration yourself rather than leave it to the chassis builder/tuner.
Centre Console Switch Layout. Most switches are momentary and we have installed green LED's so we can see at a glance whether the switch is in ON or OFF state
Steering Wheel Switch Layout
Dash Location showing the PDM30 plugged into the loom but before we screwed in onto the inclined panel behind the centre console
The following are screen shots from the initial GT4 config panel. There seems to be a real lack of info on the interweb about PDM's :( Perhaps this is an indication that this technology still has to make its way into lower level motorsport. The sharp eyed should be able to spot at least one of the problems with the initial file! The result from last weekend was that most of the wiring seemed to check out OK but we need to reconfigure some of the logic to fix the rain light, indicators and fuel pump behaviours. One really useful feature is the Test screen where you can modify the switching logic on the fly. We also used the old-fashioned techniques to check circuit continuity etc. but this is hardly necessary now with the monitoring capability of the PDM. You can also use the PDM to introduce extra failsafes to protect the engine in addition to the ECU monitored parameters so its nice to have an extra safety net :D
PDM30 Input Pins
PDM30 CAN Inputs
PDM30 Functions
PDM30 Output Pins
PDM30 CAN Outputs
PDM30 Global
Configuration
PDM30 Output Pin 1 Properties Setup
PDM30 Output Pin 1 Properties Channels
PostPosted: Sun Oct 26, 2014 1:09 pm
looking good mate, be nice to see it all done and on the road or track :)
PostPosted: Mon Oct 27, 2014 2:23 am
It looks like a tube of smarties exploded in there
PostPosted: Wed Nov 12, 2014 6:43 pm
Where did u get your roll bars and fittings from? Is it blade type if you don't mind me asking.
Cannot wait to see this in action :)
PostPosted: Wed Nov 12, 2014 7:19 pm
This must be pretty close to being up and running now??? Looking forward to more updates!
PostPosted: Wed Nov 12, 2014 11:00 pm
The ARB's are custom made using straight bars. They are not blade adjustable as the blades are really expensive to buy and we couldn't really justify it. It's easy enough to change bar diameter/thickness.
Just made a heat shield for the WRC manifold using the Nimbus GII material and mounted the brake bias adjuster on the dash. We've also had to resin 'pot' the leads for the Bosch temp sensor for the dry sump fuel tank. There is very little clearance between the top of the air intake pipe and the bottom of the tank so by effectively eliminating the flying lead connector the length of the sensor/connector is significantly reduced.
Now that we've had the PDM for a good couple of weeks we've made a note of the configuration changes we think need to be made. I'd have a go myself but thought it prudent to let the expert amend the file as he will be mapping the ECU. Hopefully will get an amended file back by the end of the week. Once that's done then the remaining big capital outlay items will be the digital dash and ECU.
PostPosted: Wed Nov 12, 2014 11:54 pm
Sounds good, who have you been using for building the car?
PostPosted: Thu Nov 13, 2014 1:08 am
Jon Edwards Motorsport (JEMS) did all the early work on the car. The electrical systems and small scale fabrication is now being done by a Group B rally enthusiast in the evenings and weekends. His day job is building mil-spec looms and as you can see from the pics the quality is awesome. Jon did the original 800+bhp 3S-GTE engine work for Adrians 200mph Corolla RunX as well as Dave Prior's engine and a few others. He also built a 1000bhp Ford YB engine in his spare time just to prove it could be done!
PostPosted: Sat Jan 17, 2015 9:53 am
What's the sketch? Eager to see more :)
PostPosted: Sun Jan 18, 2015 1:26 pm
We've been concentrating on the electrical system lately so there's not much to report on the mechanical side as the car is essentially complete. I opened the piggy bank and bought the MoTeC C125 Dash Display Logger. As with most MoTeC products you can purchase the various options separately from the basic hardware. I elected to include the I/O option as that allows the data channels from the ECU to be displayed and logged via the CAN bus. I haven't bought the logging memory option as the M130 ECU includes this as standard so there's no point in duplicating this feature. The C125 fits very neatly into the ST205 instrument panel space mounted on a carbon panel and we have also installed indicator lights, alternator warning etc. on either side of the display.
This pic shows the various display options that you can configure on the system. You can set up different screens for Race, Practice and Dyno for example.
One of the good points about the MoTeC kit is the documentation and support. You can download the software and configure and test it all off-line. I find this feature very helpful as the car is a long drive away and I only get the chance to work on it every couple of weeks.
The C125 interfaces with other MoTeC devices, along with most popular standalone engine controllers. It can also display information from most OBD2 data streams. It features two separate CAN BUS inputs, along with two RS232 inputs giving a great deal of flexibility in connecting to the devices already on your car (or to the OEM systems on the car itself). Communications between your laptop and the C125 is via Ethernet, providing very fast and reliable downloads. This also means using inexpensive and easy to source Ethernet cables.
This image shows the communications setup screen, with just a few of the many pre-built communications templates available for popular devices. You can also build your own templates using the software.
The C125 features 6 0-5v inputs, 2 thermistor temp inputs, 2 digital inputs and three speed inputs. Along with these it also has a built in 3 axis accelerometer and internal temperature sensor. Like the communications screen, the setup is straight forward and there is pre-built templates for many sensors. Or you can again build your own as well. There is no need to buy special sensors specific only to this device. The C125 can work with most any sensor out there, OEM or aftermarket, providing you have the calibration data for that sensor.
Now that we have some data coming in, we can configure the C125 to display our information. The C125 features 3 pages that can be independently configured using a variety of basic template screen, then populating with the data you want to see. You can use a switch to toggle through the pages, or you can set a condition to automatically change pages for you based on one or multiple parameters.
These two pictures show some of the display templates, along with a glimpse of the setup for the parameters, units and labels for the display. The bottom row can have up to 20 “rows” setup that can be toggled through with a switch. You can also setup overrides to show pertinent data when an alarm condition is present. Screen backlighting can be adjusted via potentiometer, using a switch to toggle between two brightness levels programmed in the software, or it can be left at one fixed value.
The C125 incorporates shift lights driven via CAN. You can build your own pattern/color patterns which are triggered by just about any parameter in the system. This photo is an example of the main setup screen, a couple of shift light module (SLM) patterns and then the layout editor where you can pick your colors/position, can set the brightness for each layout, flash or steady, and the channel driving that pattern. SLM brightness can be adjusted the same as the dash backlight, either using the same controls as the dash backlight or independently controlled.
The C125 also features an alarms system, which allows you to set a variety of conditions that will trigger the alarm. From there you can have the alarm condition do various things, such as flash the SLM a specific pattern (see image above for warning pattern), flash messages and important data on the screen during alarm, or even send that data to other devices to change control strategies based on the alarm. In the image below you can see the alarm setup window, allowing up to 48 different conditions (each with multiple parameters as triggers). You can set light to flash or steady for each condition, set the warning message that comes up, and the duration the warning lasts.
Should you decide you want to now use your C125 as a logging device as well as a display, it has an available 250MB of memory. You can log up to 300 channels, across any and all the devices you have hooked to your C125, either directly or via CAN BUS. You can set the logging speed per channel, set multiple start/stop conditions and more. Analysis can be done using MoTeC’s i2 software.
The C125 also has user defined tables, both 2D and 3D, that you can apply any of the parameters in the system to the axis of, to create a new channel from the result.
An available 4 outputs, configurable for a wide variety of tasks, allow the C125 to control various devices such as fans, pumps, sprayers all based upon data parameters within the system (or the output of a table or condition).
One of the best features is the ability of the C125 to simulate data parameters, allowing you to test all systems driven by them without actually running the vehicle. Simply set each parameter you are working with to the desired value, and verify that the output or control is working how you want.
PostPosted: Sun Jan 18, 2015 10:13 pm
Looks like an impressive bit of kit - look forward to seeing it in action. :)
PostPosted: Sun Jan 18, 2015 11:00 pm
Starship Enterprise meets Millenium Falcon so it should press all the right buttons for you, if you pardon the pun :D
