It is currently Mon Oct 06, 2025 5:09 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 37  Next
PostPosted: Mon Sep 24, 2012 3:59 pm
Kris invested many hours in looking at oil fittings so he may have good ideas
I personally would use braided hoses direct to fittings on the turbo. I think you already have one there, possibly a dry break fitting
Then use Munsen rings to support the pipework - not sure what they would be called in your country but if you Google Munsen rings you can take a picture to your local house plumbing shop :oops:
PostPosted: Mon Sep 24, 2012 10:00 pm
got you, i know what you mean 8)
my issue is that a friend of mine has damaged braided hoses in front of the high temperature of the glowing turbo, i'am pretty sure that i do not become that problem on the water lines but possible on the oil lines, i think i will go the TTE corolla way with spacers for the oil support and just normal aluminium hose ends on the water side
but for no my plan is to do a brain storming with a beer and a cigarett on a chair in front if the engine once the turbo is fitted by a adapter to the manifold, that way i get the best ideas :lol:
PostPosted: Tue Sep 25, 2012 12:04 am
I would always consider using Aeroquip Fire Sleeve or similar over any fluid lines or cables running near the turbo, manifold and downpipe.
You can see from this view of the circa 1988 vintage Formula 1 Arrows -Megatron (nee-BMW Turbo) they use a combination of shielding, fire sleeve and heat sheath aluminium sleeving to protect the fluid lines etc. from both radiant heat up to 1000degC and heat soak up to 250degC
PostPosted: Tue Sep 25, 2012 10:58 am
for sure, i will use this :)
PostPosted: Sun Oct 07, 2012 1:00 pm
Hi folks,
hava a special questions to you'll, where connects that hose on the picture, one side is connected to the throttle body as shown but the other one is just laying around in my engine bay.....?
PostPosted: Sun Oct 07, 2012 3:07 pm
It goes to the charcoal canister does it not?
PostPosted: Sun Oct 07, 2012 4:37 pm
i dont know, the line wasn't connected to anything :(
but it could.....
PostPosted: Sun Oct 07, 2012 6:59 pm
i think i got it, if i follow toyodiy i looks like it is the charcoal canister
http://www.toyodiy.com/parts/p_E_1995_T ... _1708.html
geetz
PostPosted: Mon Oct 08, 2012 6:09 am
goes to charcoal cannister.
GT Four Adovansu
PostPosted: Mon Oct 08, 2012 12:19 pm
thx 8)
i'am interested in opinions to a other question, meanwhile i consider about i should leaf the air connection of the P/S pump becouse it would make the setup way easier, what do you'll think about this i'am pretty sure the haltech could controll that without problems.....?
PostPosted: Tue Oct 16, 2012 7:22 pm
another small step is done, we calculated the water amount to 350mL/min, but the oem nozzle is just able do deliver 150mL/min, the idea hit me a few weeks ago, simple make two out of one
[img][img]http://www.abload.de/img/winozzleqeyaj.jpg[/img][/IMG]
not a nie look but it works, i'am currently at 300ml/min and the package still stand simple
PostPosted: Fri Oct 19, 2012 8:27 pm
thanks to a friend, i was connected the FPR wrong so here the correct version
[img][img]http://www.abload.de/img/efinew11ska5.jpg[/img][/IMG]
[img][img]http://www.abload.de/img/efinew2xnk08.jpg[/img][/IMG]
PostPosted: Sat Oct 20, 2012 10:22 am
What does the sensor on the fuel line do?
PostPosted: Sat Oct 20, 2012 12:37 pm
it measures the fuel pressure
greetz :)
PostPosted: Fri Nov 23, 2012 8:46 pm
if everything runs clear i will get the turbo adapter tomorrow, it will look like the one in the link but is out of 1.4541and custom made from my friend, i will weld it direct to the manifold
http://www.ebay.com/itm/140574748125?it ... dd&vxp=mtr
pls note that i would / you should never use the steel quality on that ebay offert, there isn't any strange left on high temps of above 600°C
