It is currently Mon Oct 06, 2025 6:48 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 37  Next
PostPosted: Tue Jun 26, 2012 6:46 pm
little modified fuel rail so that the injector plugs fit
and then the bigger problem, clearly visible that it is not easy to make the turbo fit the intercooler especially when it shoult professionaly, but the good point is that the ST246 valvecover looks like that throttle body and ic line up well
PostPosted: Wed Jun 27, 2012 5:04 pm
here we go with the next problem, the TB isn't as easy to mount as i wish
[img][img]http://www.abload.de/img/iscllkr0.jpg[/img][/IMG]
plan A for the moment is
i blanke the ISC and will use the A/C up connector on the IC go to a haltech ISC and connect it to the intake manifold
PostPosted: Sun Jul 08, 2012 4:36 pm
Sunny wrote:
took some time to polish the combustion camber and to calculate the volume, ~48mL
I have just finished measuring one of the chambers on my head.
I used a similar technique to you but instead of the syringe (shot) I used a burette that my other half got me from work:
This has given me a figure of 48.25cc +/- 0.05cc.
For that cylinder it gives a compression ratio of 8.76:1
PostPosted: Sun Jul 08, 2012 8:38 pm
thats a great tool for that, good to see we have nearly the same volume :)
PostPosted: Tue Jul 17, 2012 5:38 pm
small update, the timing belt is mounted and works
[img][img]http://www.abload.de/img/timingbeltsyjhl.jpg[/img][/IMG]
and here a adapter plate for the ISC, in the future i will work with a haltech ISC
[img][img]http://www.abload.de/img/iscsgkkx.jpg[/img][/IMG]
looks like i come in trouble with the water inection valve.....this valve is also a troublemaker, the oem nozzle is to small in size so i had to bore them until i hit ~350mL/min, the big issue is that not the nozzle itself limit me but the valve seat, so i had bo cut the nozzle bore the valve seat, weld it together and then i can machine the nozzle to hit my target
possible i do theis on weekend
mfg
Alex
PostPosted: Tue Jul 17, 2012 8:23 pm
Looks good Sunny.
What cambelt are you using?
PostPosted: Tue Jul 17, 2012 11:57 pm
thanks, it is a Power Enterprise one :)
PostPosted: Wed Jul 18, 2012 10:03 pm
Nice work
Love the grenade pin lol!
PostPosted: Thu Jul 19, 2012 12:38 am
sorry, what is a grenade pin :lol:
PostPosted: Thu Jul 19, 2012 8:46 pm
A grenade pin is a pin you pull out of a hand grenade to arm it before you throw it at the enemy.....you used something similar by the looks of it to lock the cam wheel in place
PostPosted: Thu Jul 19, 2012 9:43 pm
ah, got it lol :lol:
thats the last i do until the first start up.....armed and dangerous :lol:
PostPosted: Sat Aug 04, 2012 10:35 pm
a few more little bits are done
a M5 thermocouple tase place, the problem was the M6 thread in the manifold so we gave'em a machining
here takes a AN8 fitting his place, truely a master of welding to get the fat fitting on the 0,8 pipe, respect
here i will built a heat shield
and the next steps are fuel press regulator and ISCV
PostPosted: Thu Aug 16, 2012 5:56 pm
another small step for me
mounted the fuel pressure regulator today, a further target was to be compact, so i used the space from the EGR system which is not utilised by jdm engines
PostPosted: Thu Aug 16, 2012 6:30 pm
a questionb to ya'll, is here anyone who can post a picture of the backside of a 3rd gen. 3S-GTE from a ST205 for me, i just need it for a better sight of things
PostPosted: Fri Sep 07, 2012 10:04 am
Sunny - do you still need these pictures? I can take photos as engine is out.
GT Four Adovansu
