It is currently Mon Oct 06, 2025 6:15 pm
Post new topic Reply to topic  [ 401 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 27  Next
PostPosted: Mon Dec 15, 2008 12:48 pm
I though JEMS was using that oldest of tried and tested implements..........Dad :lol:
PostPosted: Mon Dec 15, 2008 4:21 pm
LOL!
PostPosted: Thu Dec 18, 2008 10:31 am
looking good.
just one thing.
if suspension arms don't have left and righ handed adjuster you wont be able to adjust them when installed in vehicle..which is a must.not that i have ever used them.. wink: :lol:
PostPosted: Thu Dec 18, 2008 1:47 pm
good point DJ.....should have thought of asking about that. The kart has left and right hand threads on the steering arms for on-kart adjustability of toe-in/toe-out. Will ask the question when I see my man tomorrow.
PostPosted: Thu Dec 18, 2008 3:15 pm
I used left threaded inserts to the hub bracket and right threaded ends to the subframe allowing arms to be rotated in place.
also sleeved them 60mm with four cutouts for weld, either side very strong
glad to be of service ..
PostPosted: Thu Dec 18, 2008 3:17 pm
ps glad to see you are using McPherson not ss will work just aswell. make sure to change the pickup points for height changes front and back thus allowing correction to roll.
PostPosted: Thu Jan 22, 2009 12:02 am
A few more pics of progress to 9 January:
Fuel Pump and Filter assembly is mounted on a plate which can be easily removed for ease of maintenance
The fuel tank will be located in the space on the left hand side of the fabrication
ST202 lower suspension arm modified for lower ball joint
My old engine has been re-installed to allow mock up the intercooler and radiator pipes etc.
The drivers seat cross tubes and mounting lugs
PostPosted: Thu Jan 22, 2009 1:25 pm
WOW :shock: Looking good. 8)
Is the reason for mounting the fuel tank forward of the rear axle to do with weight distribution?
PostPosted: Thu Jan 22, 2009 11:54 pm
Coming along nicely Don. :)
I really like the removable fuel pump / filter assembly. :)
PostPosted: Fri Jan 23, 2009 12:51 am
Yes, the MSA regs for the Dunlop/Motorsport News series mean we cant cut out the boot floor or spare wheel well.
The WRC cars had a boot mounted fuel tank but for circuit racing mounting the fuel tank in front of the rear axle reduces the polar moment of inertia and keeps the weight low as well.
ts also better to keep the fuel tank away from the back of the car in case someone punts me up the aris.
PostPosted: Fri Jan 23, 2009 1:46 am
I may have missed the post but is the road course type build or a rally car?
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Fri Jan 23, 2009 1:50 am
Its being built for circuit racing. :)
PostPosted: Fri Jan 23, 2009 2:44 am
Yes, finally another update, woot! :D
Looking good as always. 8) What capacity tank are you going to use Don?
PostPosted: Sat Jan 24, 2009 10:03 am
Rene, the plan is to go for an endurance of approx 30 minutes say, around the Silverstone GP track at race pace. We think that will translate into a tank capacity of ~45 litres.
PostPosted: Tue Feb 17, 2009 1:18 am
Some pics showing the latest developments on the track build :)
Front subframe and fabricated lower suspension arms:
Rear subframe and fully adjustable lower tie rods allowing independent adjustment of both camber and toe
Solid aluminium rear differential mounting
ATL Fuel Filler cap mounted temporarily
......and now , a pic of the ultimate chassis tweak :D
