It is currently Sun Oct 05, 2025 8:02 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 56  Next
PostPosted: Sat Feb 19, 2011 11:11 am
Yes I’ve heard the standard manifolds are good for a good 400hp hence why I’m leaving mine in. Are using a 7 or 9 stud manifold? Dorris
Black CS 2771
PostPosted: Sat Feb 19, 2011 7:47 pm
mine is the 9 stud but i have snaped the top right 1 off :( so it as a 8 stud lol
PostPosted: Sat Feb 19, 2011 8:44 pm
Being a bit hand fisted :lol:
Black CS 2771
PostPosted: Sun Feb 20, 2011 7:19 pm
lol my be a little bit :)
PostPosted: Wed Feb 23, 2011 12:01 am
good news :) cp have found my rings ::) so just goto order them now £80 and £60 to ship
PostPosted: Thu Feb 24, 2011 9:03 pm
got my new rings on their way :) £108 delivered from the US should be here mid week so staring the strip down next weekend
PostPosted: Sat Feb 26, 2011 3:10 pm
dont a bit more weight saving to day.
I started to take the rear quarter panels off and found this
so i strped it out
that about all the rear striped out :) just need to start on the froun of the car, but will do that when i have the roll cage here to fit :D
PostPosted: Mon Feb 28, 2011 7:00 am
Looks like there is a bit more to the toyota sound system than I expected. No wonder its one of the better sounding stock audios I ever heard.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Sat Mar 05, 2011 6:50 pm
ok did some more work on the car today she is getting lighter :) and all so did a dry run of the rollcage go my self a cusco gage in the end
just need to take the roof lineing out then botl and weld it all in, should help stiffen up the car and help with the handeling :)
PostPosted: Sun Mar 06, 2011 12:11 am
Good series of pics showing the Cusco cage. Looks like its reasonably easy to install with the bolt in components. You mention welding, is that for the floor mount pick up points?
PostPosted: Sun Mar 06, 2011 1:17 am
you can jst botl it all in floor and every thing but ill probly weld floor and rear legs, i might weld it all i when it is place but not shore yet :)
PostPosted: Wed Mar 23, 2011 9:21 pm
got some more bits today to go in the car and nice fire eater
PostPosted: Sun Mar 27, 2011 7:32 pm
ok so did a bit more to the roll cage over the weekend
fitted new rear strut brace
I have now bolted it all in and then started to add some more roll bars to it
first get some roll cage tube
then weld the bolt in eyes
then weld the eye hook to the cage
I all so fitted a cross brace to the roll bar
need to make shore everything lines up
did the same to the rear
and you end up with this
I them painted it all up
I then made some triangulated braces to brace the roll over bar to the body of the car and fitted it to the old seat belts mounting points
after making shore it all lines up ok I them welded it all in palace
adding these rely stiffened everything up
after all of this you end up with a nice strong roll cage
PostPosted: Sun Mar 27, 2011 8:41 pm
looks like you have also a optima redtop battery, does i ask you where i can get a battery tray that fit?
PostPosted: Sun Mar 27, 2011 8:42 pm
Hello Louis
I have some manifold repairing studs available.
Stephen
