It is currently Mon Oct 06, 2025 3:41 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 37  Next
PostPosted: Wed Jan 12, 2011 10:17 pm
Yes I am going to have to get some threaded ally rod welded to my rocker cover to fix my COP in place.
When you say gen5 - do you mean gen5 3sgte? I.e. Caldina St246 type?
PostPosted: Thu Jan 13, 2011 12:05 am
I think the best option would be ST185 valve cover with boses welded in place for the COP units
PostPosted: Thu Jan 13, 2011 2:24 am
Do the cop will last with a WTA instead off an ATA that lets air cool them ?
PostPosted: Thu Jan 13, 2011 10:36 am
That is a very good question.
I suspect the answer is who knows
However the same COP units are used in other Toyotas that don't have bonnet vents so I suspect they are used to reasonable heat.
All the same it miight be a good idea to utilize the cambelt snorkel duct to blow a little cool air about. Especially as the TTE cooler will close up the gap a bit
PostPosted: Thu Jan 13, 2011 10:49 am
Sunny wrote:
the issue is that i can't can use the gen.4 cover in conjunction with the water to air intercooler core, and as toyota went back to a center feed manifold on the gen.5 i decided to try it
i also can't can use the gen.3 as there are no threads for the COP's, but if the gen.5 won't fit i'll try to make them
I'm asking because i try to find out rocker cover that fits best for individuail coils. But 3SG have not anough space above 1st cylinder....So i think there no another way, but cut&weld :-(
PostPosted: Thu Jan 13, 2011 11:24 am
Cops of ST215 are also used in Beams red and grey top only (ST202, SW20 and SXA10)
That's true Beams have an over rocket cover that is not really vented, but does the 3SGE run as hot as our boiler. As your answer says " who knows".
PostPosted: Thu Jan 13, 2011 5:46 pm
yes, caldina ST246
i'll try to mount the bonnet vent, but i trust the toyota quality :lol:
PostPosted: Tue Feb 22, 2011 8:55 pm
update
more parts arrived me
[img][img]http://img228.imageshack.us/img228/2136/miscu.jpg[/img][/IMG]
- gen.4 oilpump
- crank position sensor
- tensioner and idlers
- water pump
the gen.3 part number delivers the plastic impeller pump with his way better design
[img][img]http://img840.imageshack.us/img840/6583/waterpump.jpg[/img][/IMG]
corolla wrc exhaust manifold, 207spec
[img][img]http://img341.imageshack.us/img341/5672/corollamanifold1.jpg[/img][/IMG]
[img][img]http://img401.imageshack.us/img401/2263/corollamanifold2.jpg[/img][/IMG]
possible we modify the design to fit a T4 twin entry or we machine a adapter, the one thing that makes a adapter attractive is that we can change the position of the turbo so that he fit the IC again, but with a adapter there is one more gasket in the system -> one more thing that can faile
and tomorrow some pics from the SARD/ Denso 275L/H fuel pump
PostPosted: Tue Feb 22, 2011 10:45 pm
Looks lie the wallet has taken another pounding
Can I ask how much the crank wheel sensor was please. Mine had the plug chopped off :(
PostPosted: Wed Feb 23, 2011 4:18 pm
sure, the sensor was 141€ :(
PostPosted: Wed Feb 23, 2011 4:36 pm
ouch!
Thanks for the info
PostPosted: Wed Feb 23, 2011 7:21 pm
no problem, just in my pocket :lol:
PostPosted: Thu Feb 24, 2011 9:06 pm
and here the SARD fuel pump, she is 99% plug&play you just have to use the delivered connector (same style like oem but with different pins), and she fit the rubber
theoretical she should be the strongest plug&play fuel pump on the marke
PostPosted: Thu Feb 24, 2011 10:07 pm
Who makes the SARD fuel pump? Are there any marking on the unit?
PostPosted: Fri Feb 25, 2011 9:02 am
This doesn't look the biggest one SARD, the 280 lph, as it would be way larger, with 51mm diameter.
And it doesn't even seem to be the smaller one, the 265 lph, because it looks very different from the Sards.
The 280lph is the first from the left:
Kris, they should be rebadged Denso...
Wolf_Tm
TM 250 enduro 2 stroke
