It is currently Mon Oct 06, 2025 3:22 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 37  Next
PostPosted: Wed Feb 24, 2010 10:16 pm
Mine came with a few dents and scratches too. Luckily the only non fixable bit is the broken upper cambelt cover. I will use the one off my other engine and all is well
I did also have to clean up the water connections where they have used a knife to cut the hoses off aluminium pieces and left gouges. Nothing to cause concern though
PostPosted: Thu Feb 25, 2010 8:21 am
i think my cambelt cover is also slightly damaged and i also saw what they have done with the knife :lol:
PS.: no funny conversation about LHD and RHD driving :lol:
PostPosted: Thu Feb 25, 2010 7:10 pm
today some spec's from the fuel rail,
[img][img]http://img411.imageshack.us/img411/4456/fuelrail1.jpg[/img][/IMG]
the following adapter will fit the pressure regulator
SARD part number: SRA02 (69015) Toyota (4E-FTE/2JZ)
but i think i will go for a M12x1,25 to -06 adapter on the side, and close the regulator hole
on the fuel side is only the injector question left, what kind of SARD injector will fitt.....
what do you guys think about the damper, work such a item well or can i drop it?
explain me :)
meanwhile i think the ST215 head-cover and the water to air intercooler will not fit, a possible solution is the ST246 cover as the design is changed for a center feed intake manifold
PostPosted: Thu Feb 25, 2010 8:00 pm
It's possible!
PostPosted: Thu Feb 25, 2010 8:04 pm
two_OH_five wrote:
It's possible!
what is possible? :D
PostPosted: Thu Feb 25, 2010 8:56 pm
It's possible that a 246 cover would fit
It might be worth dropping Adrian at Fensport a line about that as he has a 246 and I'm sure he's had the IC off at some stage :D
PostPosted: Thu Feb 25, 2010 9:08 pm
i think as a good customer of fensport he will help me :)
thanks 8)
PostPosted: Fri Feb 26, 2010 5:31 pm
some pictures from the gen.4
some parts are removed yet
[img][img]http://img231.imageshack.us/img231/2664/gen43sgte.jpg[/img][/IMG]
[img][img]http://img237.imageshack.us/img237/3929/gen43sgte1.jpg[/img][/IMG]
[img][img]http://img168.imageshack.us/img168/4574/gen43sgte2.jpg[/img][/IMG]
[img][img]http://img708.imageshack.us/img708/6879/gen43sgte3.jpg[/img][/IMG]
[img][img]http://img684.imageshack.us/img684/5861/gen43sgte4.jpg[/img][/IMG]
[img][img]http://img684.imageshack.us/img684/6633/gen43sgte5.jpg[/img][/IMG]
[img][img]http://img704.imageshack.us/img704/7990/gen43sgte6.jpg[/img][/IMG]
after the end of summer i will beginn to source parts for the build up, target time for the finish is summer next year, too long but i have to do other things before :cry:
PostPosted: Sat Feb 27, 2010 8:54 pm
the cylinder wall looks very good
[img][img]http://img28.imageshack.us/img28/1192/engine3.jpg[/img][/IMG]
and the water bores,
a subtle and constant rust coat -> absolut ok
[img][img]http://img528.imageshack.us/img528/5766/engine4.jpg[/img][/IMG]
looks like the engine is in good condition :)
PostPosted: Tue Mar 09, 2010 9:28 pm
another job is done,
[img][img]http://img28.imageshack.us/img28/7793/sardfuelpump.jpg[/img][/IMG]
SARD 280L/H Fuel pump assembled to the mounting bracket and the wires are changed to 2,5mm²
PostPosted: Tue Mar 09, 2010 9:36 pm
Have you checked the bottom end of the engine yet?
Looks in similar condition to mine so far
PostPosted: Tue Mar 09, 2010 9:56 pm
Hi 205,
not yet as the engine build will not start until winter :(
i think the engine is in perfect condition
i will do the "last" few mods this sommer to the car and then i need work in winter :)
i hope to complete project taurus in 2011, and then i do a trip to the UK meeting 8)
PostPosted: Tue Mar 09, 2010 10:13 pm
Good plan :D
PostPosted: Fri Mar 19, 2010 8:06 pm
gen.4 fuel rail with earls hoses
[img][img]http://img641.imageshack.us/img641/9900/fuelrailwithhose.jpg[/img][/IMG]
if someone is interested to build a fuel line from fuel filter to fuel rail out of ealrs hoses for his ST205, i can sent a draw
PostPosted: Fri Mar 19, 2010 8:39 pm
Are you going to use that with your existing engine?
