It is currently Tue Oct 07, 2025 12:10 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 37  Next
PostPosted: Sun Aug 30, 2009 4:55 pm
Sirius, got it, thanks 8)
i think i know these engine bay :lol:
PostPosted: Mon Aug 31, 2009 1:09 am
Mud - whereabouts are you measuring the engine water temp? (i.e. where is the probe sited)
PostPosted: Mon Aug 31, 2009 10:20 am
it's measured in the top rad hose Kris
PostPosted: Mon Aug 31, 2009 5:05 pm
Correct Steve - top rad hose.
Oil temp is measured in the sump.
PostPosted: Tue Sep 01, 2009 10:05 am
I am not sure if it has been mentioned but Nigels water temps are a littel concerning if they were measured during a run/cool down lap.
I suspect that they were either when the car was stationary before bonnet lifted or after turn off of engine when you have no water flow but for natural convection?
With a TRD stat and Koyo Nigels figures seem quite high for a few laps?
PostPosted: Tue Sep 01, 2009 2:01 pm
I think we've mentioned this before but AFAIK Nigel hasn't yet flushed the cooling system on his engine. I suspect this might improve matters a little although with 300+bhp cooling even with a TRD 'stat and Koyo will still be marginal. When I did the TSS event at Woodbridge I short-shifted to avoid high revs and possible water pump cavitation issues which would cause high coolant temps. As most people know I am re-engineering the cooling system on my track toy to cope with sustained track sessions.
PostPosted: Tue Sep 01, 2009 2:12 pm
i never heared my fans running after a rallycross turn, they started in the drivers-location where you have to drive gentle, and i speak from a curve to curve circuit and low speed + high rev, it also had around 30°C outside last time
to upgrade the cooling system, try to become more air through the radiator package,
you can read these topic complete as i played a lot this year with cooling
PostPosted: Tue Sep 01, 2009 7:12 pm
I suspect that they were either when the car was stationary before bonnet lifted...
Correct :)
Not yet :oops: ...it's on the to do list :wink:
I personally think it is more to do with the close-ratio gearbox.
Everything is running that much faster and thus generating more heat.
...more air through the radiator...
This would definitely help.
Currently have a few oil coolers in front which limit air flow.
Will probably look at ducting air towards the rad.
PostPosted: Tue Sep 01, 2009 11:22 pm
Nigel (and everyone else!)
It might be worth dropping the makers of this a line
Bilt Hamber stuff generally has a great rep. IF you could drop this in the cooling system overnight without it eating everything rubber it could be a greak block internal cleaner (short of hot tanking the engine which is *slightly* problematical with the engine in the car :lol: )
PostPosted: Thu Sep 03, 2009 7:11 pm
and the party goes on
the following is on my list
- spal fan mounting
- activating the breathing tank
- coolant change to a 1:1,5 / antifreeze:water with 2% millers extra cool
overview
[img][img]http://img267.imageshack.us/img267/2479/lfterumbau.jpg[/img][/IMG]
i blow out the rest water with my mouth so good as possible, better i'll take a wife with me next time :D :D :D
before
[img][img]http://img527.imageshack.us/img527/4416/lftervorher.jpg[/img][/IMG]
after
[img][img]http://img193.imageshack.us/img193/1081/lfternacher.jpg[/img][/IMG]
you can see the radiator better, air will flow better i think
i will use the OEM connectors on the spal fans, it is very easy, blue wire to blue wire at all fans
tomorrow i wil mount the fans and weld a connector on the stainlesss pipe to make the breathing tank work
PostPosted: Fri Sep 04, 2009 7:40 am
Great stuff... I toyed with just fitting 1 spal fan when I upgraded the radiator... this would NOT provide enough cooling, 2 fans should be fitted, even to a super thick aluminium Koyo
PostPosted: Fri Sep 04, 2009 1:34 pm
I already have twin 12" spal fans fitted to my Koyo :wink:
I believe that Mike has twin 11" spal fans fitted to his.
PostPosted: Fri Sep 04, 2009 3:11 pm
i use
- 336mm, 63mm, 2080m³/h -> engine
- 310mm, 52mm, 1630m³/h -> A/C
and now i go to work :)
PostPosted: Fri Sep 04, 2009 10:41 pm
Mike has 2 slimline Suction (Puller) Spal fans which are 280mm x 52mm 1500cfm (VA09-AP8/C-54A).
I have 2 slimline Suction (Puller) Spal fans which are 305mm x 52mm 1750cfm (VA10-AP10/C-61A).
PostPosted: Sat Sep 05, 2009 1:10 pm
spal fans with toyota connectors
[img][img]http://img168.imageshack.us/img168/9739/lfter1.jpg[/img][/IMG]
and the breathing tank
[img][img]http://img168.imageshack.us/img168/9366/breathingtank2.jpg[/img][/IMG]
[img][img]http://img32.imageshack.us/img32/7619/breathingtank5.jpg[/img][/IMG]
[img][img]http://img32.imageshack.us/img32/1509/breathingtank4.jpg[/img][/IMG]
i forget to make pictures from the modifyed radiator cap, but i only cut the lower part
i also taped the radiator for more pressure in front of them, a approved solution
[img][img]http://img213.imageshack.us/img213/5162/khlerabgeklebt.jpg[/img][/IMG]
and a close-up
[img][img]http://img32.imageshack.us/img32/5910/breathingtank3.jpg[/img][/IMG]
the breathing tank works nice, i can see the bubbles
it looks like that the spal fans work less then the OEM, a delusion as they do not run so long against OEM
i also changed for a 1:1,5 mixture coolant:water with 2% millers extra cool, should mean that the car need longer to become themp. becouse of more water but i have it after 1km (at 10:00 when it is a bit cold), the only explanation i have is millers but i'am not sure yet
and the last mod i plan for 2009 is to get sparco seats, glad for my back :D
then i can come with my car to the next meeting to visit you all :)
