It is currently Sun Oct 05, 2025 12:22 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 52, 53, 54, 55, 56  Next
PostPosted: Fri Dec 15, 2017 5:38 pm
that's should make sure I don't get head lift :)
ecu charge temp sensor boss all welded on
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Tue Dec 19, 2017 5:28 pm
heads back from the machine shop with new ARP Sleeve washers fitted, and now built back up with the JUN264 cams ready to fit on the block
BRD Page
PostPosted: Sat Dec 30, 2017 3:24 pm
bit more wiring done for the 3 port solenoid
and getting the cam pulley cover ready to dip
and head is not on and intake manifold
BRD Page
PostPosted: Fri Jan 19, 2018 6:12 pm
bit more work done, new top feed and 1000cc injectors fitted
BRD Page
PostPosted: Thu Jan 25, 2018 8:20 pm
let the fun begin, new hard pipe set up getting made from intercooler to throttle body, then new 50mm dump valve to be fitted, then onto the manifold, external 44mm waste gate piping, that's the hard pipe mocked up for the cold side, just need to get it all welded up.
BRD Page
PostPosted: Sun Jan 28, 2018 4:12 pm
cold side hard pipe done, just the 50mm dump valve to fit then paint
BRD Page
PostPosted: Tue Jan 30, 2018 9:12 pm
cold side hard pipe all done and 50mm dump valve fitted
BRD Page
PostPosted: Sun Feb 04, 2018 3:29 pm
few more hours sorting the fuse box out and most of the loom back in the car
BRD Page
PostPosted: Wed Feb 14, 2018 4:57 pm
so new manifold getting made :)
BRD Page
PostPosted: Sat Feb 17, 2018 4:43 pm
wont be long now :)
BRD Page
PostPosted: Sun Feb 18, 2018 10:07 pm
the new manifold for the BRD track car is all done, and soon to be on its way to me, big thanks to Viktor Soara for all the work https://www.facebook.com/Soara-Performa ... 949252751/
BRD Page
PostPosted: Wed Feb 21, 2018 12:47 pm
Nice,
When is the manifold arriving? I've been chatting to Viktor about getting a T4 Twinscroll.
PostPosted: Wed Feb 21, 2018 6:48 pm
hoping some time next week, the work he does is very nice only niggle it having to sort out the payment as has to be sent to Western Union, so have to set all that up witch im doing at the moment
BRD Page
PostPosted: Thu Mar 08, 2018 9:12 pm
test fitting the new manifold
BRD Page
PostPosted: Sun Mar 11, 2018 1:33 pm
so with the new manifold on, the alternator is a bit to close, so now moving it to below were the A/C compressor us to be.
just need to clean the bracket up and then sort out an adjustable tension bar, and it looks like the betl will just clear the timing cover
and the bonnet fits :)
BRD Page
