It is currently Tue May 28, 2024 12:23 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Dec 16, 2016 9:48 am
I brought to you how I solved the problem with a thud on the suspension arms SSS.
I really like to use it SSS suspension arms, because I had the opportunity to compare with McPherson suspension, because like last machine was ST-202.
But after the purchase, I discovered a terrible knock on all the front suspension, which has been difficult to locate.
I started to deal with this problem. :cry:
e-mail vad07@inbox.ru
PostPosted: Fri Dec 16, 2016 10:35 am
The photo shows the condition of joints and bushings fingers under which they operate.
https://drive.google.com/drive/folders/ ... zloQURlVTg
PostPosted: Fri Dec 16, 2016 10:53 am
More photos bushings who worked in arms:
https://drive.google.com/drive/folders/ ... 3prdGt6NzQ
PostPosted: Fri Dec 16, 2016 11:08 am
We handle fingers leverage hinges.
Grinding, but not too much because there is a certain depth of hardening. Finger in soft and hard top.
https://drive.google.com/drive/folders/ ... zZsRFFRT1k
PostPosted: Fri Dec 16, 2016 12:22 pm
Links work?
PostPosted: Fri Dec 16, 2016 7:52 pm
Looks like good work, have you re assembled them?
What was the result?
PostPosted: Sat Dec 17, 2016 6:39 am
Yes of course I brought back and 3 years they go. :)
Here are a few photos that would understand the process of revival of suspension arms:
In the photo on the link seen all kinds of plugs, which are used within the arms. This new hub made using the machine with numerical control software.
https://drive.google.com/drive/folders/ ... lRkTnlQVm8
PostPosted: Sat Dec 17, 2016 6:44 am
More photos: https://drive.google.com/drive/folders/ ... 21OazB0VjQ
PostPosted: Sat Dec 17, 2016 6:50 am
General view of the SSS control arms before the assembly (couples details in the photo is not enough, but you can understand the scale).
https://drive.google.com/drive/folders/ ... lVlM1NVcVk
PostPosted: Sat Dec 17, 2016 7:33 am
Photos ready suspension arms SSS:
Myself I levers did three years ago.
In the photo one of many of my works.
https://drive.google.com/drive/folders/ ... HMwM2hpMnM
PostPosted: Sat Dec 17, 2016 7:41 am
Here's another example embodiment.
There are replacement of bushings in the suspension arm banana (yellow polyurethane).
https://drive.google.com/drive/folders/ ... 2ZYUm9YZm8
PostPosted: Sat Dec 17, 2016 5:57 pm
This looks very interesting. :)
PostPosted: Sat Dec 17, 2016 6:52 pm
Oh sure. Most importantly, no longer need to buy new suspension arms. Just pull out the pin, unscrew the back cover and change the sleeve and on the back of new arms... :)
PostPosted: Sun Dec 18, 2016 12:02 pm
Great work!
PostPosted: Mon Dec 19, 2016 6:04 am
Kris wrote:
Great work!
Thank you for your appreciation of my work.
Users browsing this forum: No registered users and 0 guests
