Author |
Message |
Spam
Posted: Wed Jun 22, 2016 11:28 am |
New Poster |
Joined: Mon Aug 17, 2015 2:28 pm Posts: 37 Location: Surrey
I need to do a comp test on my st205
Can this be done without totally removing the charge cooler tank? Can it be moved to gain access.
Any hints would be most appreciated.
Top |
Davem45r
Posted: Wed Jun 22, 2016 9:00 pm |
Clubman |
Joined: Tue Feb 12, 2013 10:01 am Posts: 79 Location: Cheltenham
Yes it can be done without totally removing the charge cooler. You have to unbolt it lift and rotate it - think there is a guide for replacing the plugs that illustrates how.
Top |
TrackToyFour
Posted: Wed Jun 22, 2016 9:04 pm |
Club Staff |
Joined: Wed Jul 13, 2005 12:06 am Posts: 4743 Location: Perth, Western Australia
You really need to move the charge cooler to allow access for fitting the compression gauge. This isn't too difficult but it can be a bit fiddly dislodging the throttle body rubber hose and the turbo compressor hose to allow the charge cooler tank to be moved. The charge cooler coolant hoses might not allow you to move the charge cooler enough to fit the gauge so you might end up having to drain the charge cooler so it can be removed completely.
_________________ Don GT4DC Chairman 1994 Toyota Celica GT-Four ST205WRC JDM 269bhp @ 0.9bar 1994 Toyota Celica GT-Four Special GT 590bhp @ 1.8bar 1989 Van Diemen RF88/89 Formula Ford 1600 2008 Nissan Patrol GU 3.0L ZD30DDTi 154bhp
Top |
Sirius
Posted: Wed Jun 22, 2016 10:25 pm |
Club Staff |
Joined: Wed Jul 13, 2005 12:14 am Posts: 3267 Location: Camberley, Surrey
You won't have to drain the cooler you can just tilt it up out of the way. A block of wood etc is handy to prop it up on. There is a fair bit of flex in the hoses just don't be too vigorous with them as they will likely be 20 years old now.
_________________ GT4DC Events Co-ordinator 1996 ST205 UK
Top |
Spam
Posted: Thu Jun 23, 2016 12:53 pm |
New Poster |
Thanks for the advice chaps. Gonna give it a go... the lift and tilt option.
One thing... while doing the test was going to replace the plugs.. would grade 7 iridium be ok?
Top |
Diceman
Posted: Thu Jun 23, 2016 4:14 pm |
Club Staff |
Joined: Wed Jul 13, 2005 6:54 pm Posts: 3486 Location: On Top
Standard grade is 6. Running 7 on a standard boost engine may foul the plugs unless you give it lots of throttle lots of the time.
I'm not sure of your engine/boost but if running higher boost at say 1.2 bar plus then the grade 7 seems a sensible route. IIRC I ran the grade 7 equiv denso iridiums when running 1.35 bar they were fine but at low boost during initial mapping they fouled and needed cleaning occasionally. (could have been the over-fuelling during mapping??)
_________________ JP GT4DC Treasurer
Grey St185 RC Silver BMW E46 M3 Multicolour yawn Honda VFR400 Silver Honda Civic Type-R
Top |
