It is currently Sun Apr 28, 2024 12:22 pm
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Aug 24, 2015 12:05 pm
a few more of the a pillars and the area around the rear quarters that need cleaning up prior to painting
PostPosted: Mon Dec 14, 2015 10:16 am
Been a while since I have been over to Blackburn and updated this one.
The car had been outside under a cover and the damp was getting to it but Martin has it in the unit now and its dried out and work is progressing nicely.
Its been to the shot blasters for the rear arches and inner sills blasting and Martin has just about finished the off side rear quarter and rear arch.
I didnt take photos but Martin has some
I spent the day removing the surface rust that was coming through and primered the fresh surface as a temporary measure until its ready for painting which wont be that far off now
PostPosted: Wed Jan 13, 2016 10:09 am
Another day spent fettling last Saturday
Near side rust cut out and shot blasted and primered
rear subframe and tank removed and rust ground out
primered
wayoyled
PostPosted: Fri Feb 26, 2016 1:13 pm
My garage has become very untidy so I have attempted to tidy up the compressor and air lines etc..... so as to avoid tripping up over things and make life a bit easier for myself
I saw Nials set up and liked what I saw so did my own version.
PostPosted: Sun Apr 24, 2016 8:28 pm
I have spent the last god knows how many weeks filling the bodywork where the welding has been carried out, much sanding, guide coats, filling, sanding, guide coats, filling, sanding later and its ready for primer.
I have sprayed the anti stone chip to the sills and also gave the primer a go on the bonnet. It hasnt turned out too bad for a first time attempt.
PostPosted: Sun Apr 24, 2016 8:29 pm
PostPosted: Mon May 30, 2016 8:17 pm
Just about completed applying the primer
PostPosted: Thu Jul 28, 2016 8:39 pm
Borrowed the beaver tail from work on Saturday and dropped it off at the painters
Called in Tuesday to see how things were going and they were on with flatting off ready for further primer.
Called in today at the paint shop to see how it was going
Should be collecting on Saturday
PostPosted: Sun Jul 31, 2016 5:37 pm
Looks good that Dave.I'll have to come over again, when I get my crate sorted out.
Sent from my Nexus 9
PostPosted: Mon Aug 01, 2016 9:36 am
Body painted and back home, the bumpers etc will be complete tomorrow
PostPosted: Tue Aug 09, 2016 10:31 am
Putting it back together, its a slow process, everything has to be cleaned before it goes back in pls I have to remember where it all goes and where I put the stuff for safe keeping :oops:
PostPosted: Tue Aug 09, 2016 10:39 pm
How long did it take to get the dash etc back into place? Good work. :)
PostPosted: Wed Aug 10, 2016 8:26 am
A couple of hours for the dash and interior, thats once I have tracked the parts and jars of fixings down and cleaned everything up.
Basically if some thing is a 30 minute job to do, multiply by 2 at least lol
Fitting the wheel arch liners is probably an hours work including jacking up, removing wheels, putting in the gromets and fitting the liners. However when the liners are buried in the greenhouse under the interior trim and seats and the fittings are in one of a dozen jars (marked up obviously!) plus I clean all the plastics with autoglym trim cleaner and copper ease all the screws / bolts etc.... it becomes a 2 hour job
Its good to see it coming together though :)
PostPosted: Wed Aug 10, 2016 10:58 pm
More pics please!
Are you going to fit the glass yourself or outsource? Thinking of the bonded rear quarter glass in particular.
Users browsing this forum: No registered users and 176 guests
