It is currently Mon Apr 29, 2024 7:15 am
 Post subject: Charge cooler
PostPosted: Mon Sep 28, 2015 4:59 pm
Put a second hand charge cooler on I can feel it buzzing in pipes but there's no movement in charge cooler Evan when I Rev it to get it to start would I have the pipes on wrong way cheers
 Post subject: Re: Charge cooler
PostPosted: Mon Sep 28, 2015 9:52 pm
If you have fitted a second hand charge cooler pump was it a reconditioned item or sourced from a breakers yard?
If the pump is working properly you should see the charge coolant swirling when you rev the engine. If not, then either there is an air lock in the hoses or the pump isn't functioning.
PostPosted: Tue Sep 29, 2015 1:43 pm
Got it of a breaker he sed it's a good one but no reconditioned how would you check of air lock I should of left it in the garage lol
PostPosted: Fri Oct 23, 2015 6:49 pm
Car Model: ST165
What was wrong with your old pump, noisy?
As mentioned above the fluid level should drop slightly when the pump kicks in.
Any error codes?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Tue Nov 10, 2015 9:30 pm
Ye old pump was realy noisy you can feel it vibrate but not pumping not movement in charge cooler
PostPosted: Tue Nov 10, 2015 11:33 pm
Car Model: ST165
Any error codes?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Wed Nov 11, 2015 12:15 am
I'll find out 2mara get back to ye
PostPosted: Tue Mar 01, 2016 9:16 am
Car Model: ST165
How did you get on with this?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
Users browsing this forum: No registered users and 84 guests
