It is currently Mon Oct 06, 2025 1:28 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 33, 34, 35, 36, 37  Next
 Post subject: Re: Project Taurus
PostPosted: Tue Dec 31, 2013 12:47 pm
is not an option becouse i want a full fitting box, means
- fit the intake pipe in the chassis
- fit the air filter element
- fit the turbos position
i just want the design of the tte box but except of this it is sub-optimal :lol:
PostPosted: Tue Dec 31, 2013 5:41 pm
Do what I did initially and make your own. It's amazing what you can do with extruded polystyrene and fibreglass.
PostPosted: Tue Dec 31, 2013 5:44 pm
Another option which I thought about was making a metal one. Cutting away a square from the inner wing/wheel arch, make a box out of metal and weld this over the hole, the air filter fits onto this, then make a TTE style top to fit over it......don't know if that make sence?
PostPosted: Thu Jan 02, 2014 8:57 pm
Hi folks,
doing my own isn'T a good option becouse i never did any moulding or fiberglass work, out of metal is still a option but therefore i need a
good handcrafts man....possible i find one but for now i would go the carbon fiber way and a specialist who can do all the work
welding on the chassis is not an option for me, i want to stay oem in that case, if i doesnt get a solution i just let the oem box stay in position
even i need the space for my custom oil catch can
greedz
PostPosted: Wed Jun 25, 2014 10:57 am
if anyone is interested in my engine, just drop me a message
PostPosted: Tue Jun 30, 2015 11:53 pm
Hi folks,
curently i am going for on of these
http://speed-source.net/?wpsc-product=t ... ch-pushrod
should i buy the ST185 or MR2 turbo one....which fit the ST205 gearbox?
hope you can help me
PostPosted: Wed Jul 01, 2015 6:57 am
email them and ask if any difference. I wouldn't think that a pushrod would be different between the gearboxes.
GT Four Adovansu
PostPosted: Wed Jul 01, 2015 11:11 am
will do this,
my key problem is the clutch, after the new engine was setup i notices that the clutch opening point was at the floor so the pedal was fully pushed
i simple dediced to set the pedal more away from the floor to get the opening point higher, the shifting is not that exact as oem any more the gear often
went in that easy, now i try this pushrod and set the pedal position new
i'am glad for any ideas of professionals too.....
PostPosted: Thu Jul 02, 2015 7:11 am
if you need measurements of the speed source st185 push rod I am happy to provide
GT Four Adovansu
PostPosted: Thu Jul 02, 2015 10:20 pm
thanks for the offert, but curently i have no oem one to compare as my car is at the tuner, better tuned map + 8000rpm now :lol:
PostPosted: Sat Jul 04, 2015 2:03 pm
ne setup online, 8000rpm, 1,7bar boost, 3rd gear 180km/h :lol:
unfortunelty no dyno sheet
PostPosted: Sun Jul 05, 2015 12:27 pm
took these measurements back in 2013
GT Four Adovansu
PostPosted: Sun Jul 05, 2015 1:18 pm
thanks a lot, speed source aint answer me looks like i built my own pushrod
....and this are the measurements of the oem one or longer?
PostPosted: Sun Jul 05, 2015 7:39 pm
The pictures are of the Speed Source push rod. Apparently they answer questions on their facebook page: https://www.facebook.com/pages/Speed-So ... 0234467482
GT Four Adovansu
PostPosted: Sun Jul 05, 2015 10:21 pm
thx again 8)
