It is currently Mon May 20, 2024 1:10 pm
 Post subject: Sumps...
PostPosted: Sun Mar 22, 2015 6:48 pm
does the Rev 3 sump fit straight on the Rev 2 block?
 Post subject: Re: Sumps...
PostPosted: Sun Mar 22, 2015 8:39 pm
Simple answer is no. :)
PostPosted: Sun Mar 22, 2015 10:55 pm
More complex answer, almost.
You need the rev3 oil pump - you will then also need the rev 3 cam belt.
You need to to drill & tap some of the mounting holes for the rev3 scraper plate (rev 2 it's built into the sump)..
A couple of the sump to block bolt holes don't line up, so will need block drilling & tapping or sump drilling.
PostPosted: Mon Mar 23, 2015 12:47 am
.....subtitle to the above post should read: I'll MAKE it fit :mrgreen:
PostPosted: Mon Mar 23, 2015 9:44 am
:D
Can anyone see any benefit in just swapping over the sump between Rev2 and 3?
PostPosted: Mon Mar 23, 2015 10:13 am
ok, just wondering.
whats peoples prefrance between the rev2 & 3 for tuning?
PostPosted: Mon Mar 23, 2015 1:06 pm
I would say that people overwhelmingly use the Rev3 over the Rev2.
Why is a much bigger question which is tougher to answer, there a certainly more bigger power ST205's out there than ST185's but that is in my opinion at least partially to do with the popularity of the ST205 over the ST185.
PostPosted: Mon Mar 23, 2015 1:10 pm
just wondering as i have a Rev 2 block and Rev 3 head
PostPosted: Tue Mar 24, 2015 11:03 am
1) The oil filter & sump & baffling setup is much better on the ST205.
2) There is some babble on the internet that the ST205 blocks suffered more from cracking.
Item 1 is clear - Item 2 is not.
PostPosted: Tue Mar 24, 2015 11:12 am
thank you very much, so really a baffled sump would be a good addition to the rev 2 bottom end
PostPosted: Tue Mar 24, 2015 3:28 pm
I think number 2 is due to their being a lot more tuned Rev 3 engines out there.
PostPosted: Tue Mar 24, 2015 7:28 pm
When you take into account the USA 3sgte tuning scene I would suggest the rev 2 is more common in high power guise than rev 3.
It is speculative either way.
PostPosted: Thu Mar 26, 2015 2:23 pm
http://www.moroso.com/eb/catalog/search ... Term=20935
just get a moroso sump for a rev2 .... don't make them for a rev 3
PostPosted: Thu Mar 26, 2015 10:23 pm
gt4hazee wrote:
http://www.moroso.com/eb/catalog/search/advancedsearch.action?mustOccur=true&resetOffset=true&appn=&can=&modelFilter=-1&yearFilter=ALL&pr=&xxprName=&xxprReturn=&searchTerm=20935
+1
That's what I have (will be using).
Users browsing this forum: No registered users and 0 guests
