Hi all
I have a 185 gt4 and i have owned it for around 3 years and it's come to the time
where I either sell it or do the work required
I really want to keep it but if it costs too much it will have to go which I will be gutted about
Here is the situation:
Clutch really needs doing been needing changing for a long time and I was advised
to change some other bits while engine is out such as
water pump
front crank shaft oil seal
rear crank shaft oil seal
driver side drive shaft oil seal
passenger side drive shaft oil seal
timing belt
hydraulic tensioner
plus I need part of the prop shaft as when I change gear there is a bang, it's the rubber mount
I believe in the prop shaft
also i may need a new hub on the front passenger side or the flange but getting it taken
out in a few days so will know for sure what the situation is
I have already contacted TCB and they were the ones that recommended I change the bits above
while everything is out
Thy said the "solid ace" clutch will be good enough as mine is only pushing out around 220 - 250bhp
I have just entered some part numbers in that OEM search and some of them are coming out really
cheap but they are in austrailia and not sure how much post will be etc
I have some other bits to do on the car but these are the main jobs, if I can get all this
done for a reasonable price I will be able to keep the car
Any help would be much appreciated
Thanks
Paul
