It is currently Mon May 20, 2024 11:07 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 32, 33, 34, 35, 36, 37  Next
 Post subject: Re: Project Taurus
PostPosted: Mon Sep 02, 2013 12:26 am
That's really good news Sunny!
PostPosted: Mon Sep 02, 2013 7:07 am
Sunny wrote:
here the next mission for august
K&N 33-2438, 318x233x44mm + custom carbon airbox
here the company i talk to
http://www.carbonmax.cz/
hope to get the prices under controll to get it done
You need to take the plastic off that filter at some point, lol
:D
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Mon Sep 02, 2013 2:34 pm
lol :lol:
you are lying :lol:
no airbox yet, looks like it becomes a project for the next year
PostPosted: Sat Sep 07, 2013 11:35 am
PostPosted: Sat Sep 07, 2013 2:12 pm
These look like good numbers Sunny especially the torque which should make it very driveable. Are you happy with them?
PostPosted: Sat Sep 07, 2013 3:27 pm
Nice number!!
What boost pressure?
Congratz!
ST185 CS #1845
PostPosted: Sat Sep 07, 2013 7:04 pm
fully driveable even in the city, 1,4bar boost
my tuner said that this is the best 3S he ever did, hope it will be in the future too, a friend of mine activates his ST205 with EFR7064 soon :lol:
more tourque is possible but my tuner takes care on the gearbox :lol:
and yes i'am happy, from yesterday until now i spent 100€ just for gas :lol:
hope to get telemetric datas soon, data log is activated
once the next year bores me i built the WI to get the falling touque from 5000rpm under controll
PostPosted: Sat Sep 07, 2013 9:54 pm
I don't think I've seen such high power from an ST205 with the WTA intercooler :D I guess the TTE thicker core must help keep the air charge temperatures under control. Allegedly the TTE Group A ST205 could run ~400bhp with the turbo restrictor removed and remapped to suit according to Neal Bates who ran one for Toyota Team Australia. I don't know if the water injection and intercooler spray bar were activated on his car but I suspect they were! If you were running 1.4bar through a WTA setup without WI I would be a bit worried about detonation. Are you using 102 octane race fuel or taking some other precautions?
PostPosted: Sun Sep 08, 2013 11:29 am
the IC works perfect, i don't give a f*ck on ATA :lol:
i just need to know how i can download the data login from the ecu to the computer and then i post some specs
the engine runs ROZ98 without any mods, no detonation
the tuner said that he was able to lean the mixture more for further 15-20PS, but he gaves that engine a more safe map
i just wonder about the EGT, he said around 800°C, however i need to activate that channel on the ECU again to get datas,
i also hope that the temp isn't around 700°C on any point in front of the thermocouples curie point
PostPosted: Sat Sep 21, 2013 9:55 pm
IAT while under boost 40-45°C, highest IAT 60°C (not under boost)
here we see heat soak when not under boost, but no problem once the boost comes is the same time with low IAT
peak boost = 1,5bar sometimes 1,6bar depending on the spool up and temps outside, but should be mapped to 1,4bar (could need some more tune)
a longer time under boost and the EGT goes up to slightly above 900°C
oil temp. around 100°C when reving hard
new peak pressure from today, 9,5bar when cold, around 6bar when warm and under rpm, 3,5bar at idle
PostPosted: Sun Sep 22, 2013 11:57 am
can anyone explaine me the toyota oil filter?
i'am told that there is a pressure valve in it, when the oil is cold the pressure is that high so that i can by-pass the filter?
if it is that, possible a near miss for the ceramic ball bearings if foreign material found his way to the turbo......
/edit
found the answer in the manuel
PostPosted: Sun Sep 22, 2013 12:49 pm
9,5 bar oilpressure sound high to me. I only get about 6 bar when cold.
900 degrees is okay from what I have read. My car has a theromcouple in the collector after the exhaustmanifold befor the turbo.
my car reads around 500 when idleing at 14,... A/F and around 900 on 1,2 bar boost(+/- 11,5 A/F).
ST185 CS #1845
PostPosted: Sun Sep 22, 2013 4:33 pm
our egt values are nearly identycall, but that high oil press is due to the beams oil pump and just when i start the engine iirc i have 6,5bar at cold idle and 3,5bar at hot idle
5,5bar when gentle driving and 6bar under revs, everything is around +10% oil flow against the gen.3 oil pump
i just want to know the relief pressure of the oil filter, dropped Tony from fensport my question and i hope to get some trd or blitz specs.....
PostPosted: Mon Dec 30, 2013 12:59 pm
still got no airbox made :(
i'am wondering if RT-performance could help, but even it.....it is nearly not possible to do a draw with all that measurements...........
greedz
PostPosted: Mon Dec 30, 2013 5:23 pm
greedz
Why not just buy the TTE copy one from the OC?
Users browsing this forum: No registered users and 0 guests
