It is currently Wed Oct 08, 2025 10:44 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: st205 blown dipstick
PostPosted: Wed Sep 18, 2013 1:05 am
If It's a 3s engine I would guess so but not 100% sure. Cams are better on the n/a
PostPosted: Wed Sep 18, 2013 9:15 pm
thats what we thought. Got a good replacement head coming, So will fit head and pressure test on friday hopefully.
PostPosted: Thu Sep 19, 2013 7:46 am
Nah, Im pretty sure you need a 3s-gte head
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Fri Sep 20, 2013 10:14 am
tjaytoymota wrote:
yeah think your right he seems to of put a catch can on which im certain is not plumbed right and is bone dry, ripped head off today and we discovered is fitted with steel gasket that im sure is weeping prob due to not having skimmed head as to who did this we are not sure as gord who did rebuild in 2010 and sold car to last owner said he fitted standard gasket,have found a burned out valve in no 2 also valve stems seem to be wet of oil havent removed pistons as yet as all seems good and bores look perfect.
Unfortunately I think he did the work himself... he is on facebook if you search for his name. Gord smith i think it was.
His car was always having problems I think as i had many arguments with him about the reliabillity of a four and he said they were crap, I argued that 145,000miles without so much as a turbo or headgasket change when looked after they were tanks.
So I know his car had multiple engine problems
PostPosted: Fri Sep 20, 2013 8:40 pm
285084 as i type this, head never lifted yet ! Only bottom end shells. Q turbo (253810 miles) and even compression figures across the four cylinders. Altho getting lower each time i check. Ohh, last 150000 miles running upto 17psi.
Darryl
Darryl
PostPosted: Sun Sep 22, 2013 1:30 pm
well its all back together and seems to running fine, no smoke and not over heating. It is however throwing a code now for the heated 02 sensor. Will have a look at this as it probably got coated in oil and unburnt fuel form number 2 . Apart from that it looks like its all systems go again, thanks for all the advice, just got to wait for an admin to accept me on my own name, i have filled in the registration and it says an admin wll accept and email me but nothing yet..
Cheers again all
Gavin
PostPosted: Sun Sep 22, 2013 5:25 pm
So, what do you think/know the problem was?
And was it a cheap fix?
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Sat Sep 28, 2013 8:23 pm
valves on pot 2 were cracked. it cost about 170 quid all in for the second hand head and gasket set. 2 days work.
PostPosted: Sun Sep 29, 2013 12:20 am
That's a new one :o Which valves were cracked, exhaust, inlet or both?
PostPosted: Sun Sep 29, 2013 1:01 am
i cant remember inlet i think. im sure tjay will know. running like a dream now tho. :P
PostPosted: Mon Sep 30, 2013 11:09 am
Burnt out exhaust valve no two cylinder also think gasket was wweping between no 1 and 2 all good now with 160 ish psi across all four
PostPosted: Mon Sep 30, 2013 6:18 pm
I had the same thing recently. 2 cracked exhaust valves(NO.2 and 3 cil.).
Oil coming out of the bov.
replaced the valves on the exhaust side, all 8. New pistonrings and HG.
Good to see you fixed the problem.
ST185 CS #1845
