It is currently Wed May 22, 2024 12:43 pm
PostPosted: Thu May 09, 2013 3:56 pm
Are there any repercussions from running a gt4 with no undertray for long periods time (i.e. 3 years)
St205 WRC - Running sweet.
PostPosted: Thu May 09, 2013 4:01 pm
There are risks to damage and overheating as the under tray protects and also filters air to aid cooling (i believe?)
But no other repercussions that I am aware of although I believe others may be better qualified to answer this more accurately.
Loosey
Loosey@gt4dc.co.uk
Storm Blue JDM ST205
Super White JDM ST205
PostPosted: Thu May 09, 2013 4:12 pm
Yes. The driveway gets black. :shock:
More potential for mechanical damage from stones etc. esp. if timing belt cover off too, and a lot more engine bay corrosion, general filth, and moisture in electrical connectors.
PostPosted: Thu May 09, 2013 4:23 pm
Car Model: ST165
datajon wrote:
1) reduces road muck getting into engine bay
2) reduce road wash doing stuff harm ie alt bearing, tensioner bearings etc
3) reduces drag
4) increase cooling for coolant radiator
5) better cooling towards charge cooler pre rad
6) better cooling towards using front mounted intercooler
7) improved handling due to smooth bottom effect
8.) better MPG.
9) toyota design & install under trays for all the above reasons
10) only lazy dim wits don't keep them on. :lol:
ST165 turbo 4WD
PostPosted: Thu May 09, 2013 4:56 pm
Agree with all the above.
I ran mine without for a while and the engine bay ended up a rusty mess.
PostPosted: Thu May 09, 2013 7:13 pm
My 205 never had them when I bought it. Any puddle of any significance at speed and the car grinds to a halt - normally in the middle of the puddle so you get your feet wet drying out the ignition.
PostPosted: Thu May 09, 2013 7:49 pm
Mind never had it either that's why I ask. There is no rust in there...YET
PostPosted: Thu May 09, 2013 8:30 pm
ALSO it prolongs the life of the oil sump :)
PostPosted: Tue May 14, 2013 12:32 am
haha, i don't have to worry about that because oil ALWAYS finds its way out of my engine and there is evidence (this time) of it on the bottom of the sump.
Last year my car amazingly teleported all of its oil out of the engine in one go never to be seen again. Caused quite a lot of damage. Nibbles had to tow me back to the nibbles repair bay...
Never got to the bottom of where it went.... Oh, Lewis witnessed it happen too.
